2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building example application on windows-x64
To: 'Michael Davidsaver' <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Sat, 30 Dec 2017 15:52:47 +0000
This is the dialog message.
These are the last frames in the stack trace.  I've indicated the current line with >>>
#ifdef _DEBUG
_CRTIMP2_PURE void __CLRCALL_PURE_OR_CDECL _Debug_message(const wchar_t *message, const wchar_t *file, unsigned int line)
     {    // report error and die
        if(::_CrtDbgReportW(_CRT_ASSERT, file, line, NULL, message)==1)
>>>            ::_CrtDbgBreak();
_CRTIMP2_PURE void __CLRCALL_PURE_OR_CDECL _Debug_message(const unsigned short *message, const unsigned short *file, unsigned int line)
        _Debug_message((wchar_t *) message, (wchar_t *) file, line);
#endif
template<class _Ty> inline
     void _Debug_pointer(const _Ty *_First, _Dbfile_t _File, _Dbline_t _Line)
     {    // test iterator for non-singularity, const pointers
     if (_First == 0)
          _DEBUG_ERROR2("invalid null pointer", _File, _Line);
template<class _InIt1,
     class _InIt2> inline
     bool equal(_InIt1 _First1, _InIt1 _Last1,
          _InIt2 _First2)
     {    // compare [_First1, _Last1) to [First2, ...)
     _DEBUG_RANGE(_First1, _Last1);
     _DEBUG_POINTER(_First2);
     return (_Equal1(_Unchecked(_First1), _Unchecked(_Last1),
>>>       _First2, _Is_checked(_First2)));
_First1, _Last1, and _First2 are all null pointers.
> -----Original Message-----
> From: Michael Davidsaver [mailto:[email protected]]
> Sent: Saturday, December 30, 2017 9:31 AM
> To: Mark Rivers
> Cc: 'Andrew Johnson'; '[email protected]'; Ralph Lange
> Subject: Re: Problem building example application on windows-x64
> On 12/30/2017 08:50 AM, Mark Rivers wrote:
> > I have attached the .tap files.  The first simmTest.tap is for windows-x64, the other files
> are all for windows-x64-static.
> Thanks.  I'll leave simmTest for Ralph.
> >> And yet they show as PASS?  Strange.  Can you capture a couple of these?
> > The dialog box gives options for Abort, Retry, and Ignore.  I had selected Ignore which is
> probably why the test passed.
> What message is shown?  I'd guess something about NULL pointer.
> I can't find a source listing, but it seems like the MSVC
> implementation of std::equal() is being extra super helpful and
> asserting that the third argument by non-NULL.  In this case
> it doesn't matter as the first two arguments are equal,
> so the NULL is not dereferenced.
> This raises a separate the question of whether std::equal() is
> specified for an empty range, and what the results should be.
> The consensus seems to be 'yes', and 'true', but I've not found
> anything authoritative.
> These issues arises when comparing empty shared_vector<>s.
> Which currently return NULL for begin(), end(), and similar.
> This seems like non-standard MSVC behavior, which I'd like to
> understand more before attempting a workaround.  The
> possibilities are 1) make shared_vector return a non-NULL
> pointers when empty(), or 2) refrain from calling
> std::equal() on empty arrays.
> > I now selected Retry which allows running the debugger.  This is the stack trace for
> testSerialization:
> >>    testSerialization.exe!std::_Debug_message(const wchar_t *
> message=0x000000013f813048, const wchar_t * file=0x000000013f813080, unsigned int
> line=3049)  Line 15 C++
> >       testSerialization.exe!std::_Debug_pointer<unsigned char>(const unsigned char *
> _First=0x0000000000000000, const wchar_t * _File=0x000000013f813080, unsigned int
> _Line=3049)  Line 692        C++
> >       testSerialization.exe!std::equal<unsigned char const * __ptr64,unsigned char const *
> __ptr64>(const unsigned char * _First1=0x0000000000000000, const unsigned char *
> _Last1=0x0000000000000000, const unsigned char * _First2=0x0000000000000000)  Line
> 3051 C++
> >       testSerialization.exe!epics::pvData::`anonymous
> namespace'::compareArray<unsigned char>(const epics::pvData::PVValueArray<unsigned
> char> * left=0x000000000028ade0, const epics::pvData::PVValueArray<unsigned char> *
> right=0x00000000002889d0)  Line 159 + 0x4c bytes        C++
> >       testSerialization.exe!epics::pvData::`anonymous namespace'::compareField(const
> epics::pvData::PVScalarArray * left=0x000000000028ade0, const
> epics::pvData::PVScalarArray * right=0x00000000002889d0)  Line 202 + 0x15 bytes
>          C++
> >       testSerialization.exe!epics::pvData::operator==(const epics::pvData::PVField &
> left={...}, const epics::pvData::PVField & right={...})  Line 339 + 0xf bytes       C++
> >       testSerialization.exe!`anonymous namespace'::testEquals()  Line 162 + 0x35 bytes
>          C++
> >       testSerialization.exe!main(int __formal=1, int __formal=1)  Line 875          C++
> >       testSerialization.exe!__tmainCRTStartup()  Line 278 + 0x19 bytes  C
> >       testSerialization.exe!mainCRTStartup()  Line 189     C
> >       kernel32.dll!00000000775259cd()
> >       [Frames below may be incorrect and/or missing, no symbols loaded for kernel32.dll]
> >       ntdll.dll!000000007775a561()
> > This is the stack trace for testPVScalarArray:
> >>    testPVScalarArray.exe!std::_Debug_message(const wchar_t *
> message=0x000000013f6a55d8, const wchar_t * file=0x000000013f6a4970, unsigned int
> >       testPVScalarArray.exe!std::_Debug_pointer<signed char>(const char *
> _First=0x0000000000000000, const wchar_t * _File=0x000000013f6a4970, unsigned int
> >       testPVScalarArray.exe!std::equal<signed char const * __ptr64,signed char const *
> __ptr64>(const char * _First1=0x0000000000000000, const char *
> _Last1=0x0000000000000000, const char * _First2=0x0000000000000000)  Line 3051
>          C++
> >       testPVScalarArray.exe!epics::pvData::`anonymous
> namespace'::compareArray<signed char>(const epics::pvData::PVValueArray<signed char>
> * left=0x0000000000314260, const epics::pvData::PVValueArray<signed char> *
> right=0x0000000000314380)  Line 159 + 0x4c bytes        C++
> >       testPVScalarArray.exe!epics::pvData::`anonymous namespace'::compareField(const
> epics::pvData::PVScalarArray * left=0x0000000000314260, const
> epics::pvData::PVScalarArray * right=0x0000000000314380)  Line 204 + 0x15 bytes
>          C++
> >       testPVScalarArray.exe!epics::pvData::operator==(const epics::pvData::PVField &
> >       testPVScalarArray.exe!`anonymous
> namespace'::testBasic<epics::pvData::PVValueArray<signed char> >()  Line 93 + 0x2f
> bytes            C++
> >       testPVScalarArray.exe!main(int __formal=1, int __formal=1)  Line 206      C++
> >       testPVScalarArray.exe!__tmainCRTStartup()  Line 278 + 0x19 bytes         C
> >       testPVScalarArray.exe!mainCRTStartup()  Line 189            C
> > Mark
> >> Sent: Friday, December 29, 2017 9:45 AM
> >> To: Mark Rivers
> >> On 12/29/2017 08:55 AM, Mark Rivers wrote:
> >>> I have run the runtests for windows-x64 and windows-x64-staticon VS2010.
> >>> For windows-x64 there were no dialog boxes.
> >>> For windows-x64-static there were many Debug Assertion error dialog boxes in
> >> testSerialization.t (24 times) and  testPVScalarArrat (5 times)
> >>> They all appear to be null pointer problems.
> >> Maybe the first from each test for a start?
> >>> Both also appeared to fail some tests:
> >> At this point we need to see the output of the tests.  Can you run:
> >>> make tapfiles
> >> Then collect the .tap files (test output) of the three mis-behaving tests.
> >> These should be:
> >> modules/database/test/std/O.*/simmTest.tap
> >> modules/pvData/testApp/O.*/testSerialization.tap
> >> modules/pvData/testApp/O.*/testPVScalarArray.tap
> >>> These are failures on windows-x64:
> >>> Test Summary Report
> >>> simmTest.t            (Wstat: 0 Tests: 1176 Failed: 7)
> >>>   Failed tests:  140, 315, 439-440, 665-666, 767
> >>> Files=11, Tests=3575, 13 wallclock secs ( 0.48 usr +  0.08 sys =  0.56 CPU)
> >>> Result: FAIL
> >>> Failed 1/11 test programs. 7/3575 subtests failed.
> >>> These are failures on windows-x64-static:
> >>> Test Summary Report
> >>> simmTest.t            (Wstat: 0 Tests: 1176 Failed: 3)
> >>>   Failed tests:  355-356, 439
> >>> Files=11, Tests=3575, 15 wallclock secs ( 0.50 usr +  0.03 sys =  0.53 CPU)
> >>> Result: FAIL
> >>> Failed 1/11 test programs. 3/3575 subtests failed.
> >>> This is the output for windows-x64:
> >>> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64
> >>> H:\epics-devel\base-7.0.1>make -s runtests
> >>> Snippets.t .. ok
> >>> All tests successful.
> >>> Files=1, Tests=29,  2 wallclock secs ( 0.05 usr +  0.00 sys =  0.05 CPU)
> >>> Result: PASS
> >>> epicsUnitTestTest.t ........ ok
> >>> epicsTypesTest.t ........... ok
> >>> epicsInlineTest.t .......... ok
> >>> epicsCalcTest.t ............ ok
> >>> epicsAlgorithmTest.t ....... ok
> >>> epicsMathTest.t ............ ok
> >>> epicsMMIOTest.t ............ ok
> >>> epicsEllTest.t ............. ok
> >>> epicsEnvTest.t ............. ok
> >>> epicsErrlogTest.t .......... 24/32 log client: connected to log server at "127.0.0.1:60935"
> >>> epicsErrlogTest.t .......... ok
> >>> epicsStdioTest.t ........... ok
> >>> epicsStdlibTest.t .......... ok
> >>> epicsSockResolveTest.t ..... ok
> >>> epicsStringTest.t .......... ok
> >>> epicsTimeTest.t ............ ok
> >>> epicsTimeZoneTest.t ........ ok
> >>> epicsThreadTest.t .......... ok
> >>> epicsThreadOnceTest.t ...... ok
> >>> epicsThreadPriorityTest.t .. ok
> >>> epicsThreadPrivateTest.t ... ok
> >>> epicsThreadHooksTest.t ..... ok
> >>> epicsThreadPoolTest.t ...... ok
> >>> epicsExitTest.t ............ ok
> >>> epicsTimerTest.t ........... ok
> >>> ringPointerTest.t .......... ok
> >>> ringBytesTest.t ............ ok
> >>> epicsEventTest.t ........... ok
> >>> epicsMutexTest.t ........... ok
> >>> epicsSpinTest.t ............ ok
> >>> epicsAtomicTest.t .......... ok
> >>> macDefExpandTest.t ......... ok
> >>> cvtFastTest.t .............. ok
> >>> macLibTest.t ............... ok
> >>> macLib.t ................... ok
> >>> taskwdTest.t ............... ok
> >>> blockingSockTest.t ......... ok
> >>> epicsMessageQueueTest.t .... ok
> >>> epicsStackTraceTest.t ...... ok
> >>> ipAddrToAsciiTest.t ........ ok
> >>> osiSockTest.t .............. ok
> >>> Files=40, Tests=4016, 200 wallclock secs ( 0.56 usr +  0.16 sys =  0.72 CPU)
> >>> Result: PASS
> >>> dbScanTest.t ............... ok
> >>> dbShutdownTest.t ........... ok
> >>> dbPutLinkTest.t ............ 265/320 dbJLinkInit: lexical error: invalid char in json text.
> >>>                                   {"x":bbbb}
> >>>                      (right here) ------^
> >>> dbJLinkInit: parse error: premature EOF
> >>>                                        {"z":{"good":6}
> >>> dbPutLinkTest.t ............ ok
> >>> dbLockTest.t ............... ok
> >>> dbStressTest.t ............. ok
> >>> testdbConvert.t ............ ok
> >>> callbackTest.t ............. ok
> >>> callbackParallelTest.t ..... ok
> >>> dbStateTest.t .............. ok
> >>> dbServerTest.t ............. 1/24 dbRegisterServer: 'one' registered twice?
> >>> dbRegisterServer: Bad server name 'bad name'
> >>> dbRegisterServer: Ignoring 'disabled', per environment
> >>> dbUnregisterServer: Servers still active!
> >>> dbUnregisterServer: 'toolate' not registered.
> >>> dbUnregisterServer: 'no-routines' has no stop() method.
> >>> dbServerTest.t ............. ok
> >>> dbCaStatsTest.t ............ ok
> >>> dbCaLinkTest.t ............. ok
> >>> scanIoTest.t ............... ok
> >>> dbChannelTest.t ............ ok
> >>> dbChArrTest.t .............. Starting iocInit
> >>> iocRun: All initialization complete
> >>> dbChArrTest.t .............. ok
> >>> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
> >>> chfPluginTest.t ............ ok
> >>> arrShorthandTest.t ......... ok
> >>> recGblCheckDeadbandTest.t .. ok
> >>> testPutGetTest.t ........... ok
> >>> dbStaticTest.t ............. ok
> >>> Files=20, Tests=2856, 81 wallclock secs ( 0.41 usr +  0.11 sys =  0.51 CPU)
> >>> Result: PASS
> >>> msi.t .. ok
> >>> Files=1, Tests=9,  1 wallclock secs ( 0.03 usr +  0.00 sys =  0.03 CPU)
> >>> Result: PASS
> >>> arrayOpTest.t ........... ok
> >>> recMiscTest.t ........... ok
> >>> linkRetargetLinkTest.t .. ok
> >>> linkInitTest.t .......... 1/77 dbRegisterServer: 'rsrv' registered twice?
> >>> linkInitTest.t .......... 18/77 dbRegisterServer: 'rsrv' registered twice?
> >>> linkInitTest.t .......... 60/77 dbRegisterServer: 'rsrv' registered twice?
> >>> linkInitTest.t .......... ok
> >>> compressTest.t .......... 1/116 dbRegisterServer: 'rsrv' registered twice?
> >>> compressTest.t .......... ok
> >>> asyncSoftTest.t ......... ok
> >>> softTest.t .............. ok
> >>> asTest.t ................ ok
> >>> analogMonitorTest.t ..... Starting iocInit
> >>> analogMonitorTest.t ..... ok
> >>> regressTest.t ........... 1/31 dbRegisterServer: 'rsrv' registered twice?
> >>> dbConvertJSON: parse error: trailing garbage
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>> regressTest.t ........... ok
> >>> simmTest.t .............. Failed 7/1176 subtests
> >>> Test Summary Report
> >>> Result: FAIL
> >>> tsTest.t .... ok
> >>> dbndTest.t .. ok
> >>> arrTest.t ... ok
> >>> syncTest.t .. ok
> >>> Files=4, Tests=1612,  3 wallclock secs ( 0.19 usr +  0.01 sys =  0.20 CPU)
> >>> Result: PASS
> >>> Base.t ........ ok
> >>> Breaktable.t .. ok
> >>> DBD.t ......... ok
> >>> Device.t ...... ok
> >>> Driver.t ...... ok
> >>> Function.t .... ok
> >>> Menu.t ........ ok
> >>> Recfield.t .... ok
> >>> Recordtype.t .. ok
> >>> Registrar.t ... ok
> >>> Variable.t .... ok
> >>> Files=11, Tests=287,  1 wallclock secs ( 0.03 usr +  0.06 sys =  0.09 CPU)
> >>> Result: PASS
> >>> testThread.t ............ ok
> >>> testEvent.t ............. ok
> >>> testTimer.t ............. ok
> >>> testBitSet.t ............ ok
> >>> testOverrunBitSet.t ..... ok
> >>> testByteBuffer.t ........ ok
> >>> testBaseException.t ..... ok
> >>> testSharedVector.t ...... ok
> >>> testDebugPtr.t .......... ok
> >>> testSerialization.t ..... ok
> >>> testTimeStamp.t ......... ok
> >>> testQueue.t ............. ok
> >>> testTypeCast.t .......... ok
> >>> testUnitTest.t .......... ok
> >>> testjson.t .............. ok
> >>> test_reftrack.t ......... ok
> >>> testanyscalar.t ......... ok
> >>> testBitSetUtil.t ........ ok
> >>> testIntrospect.t ........ ok
> >>> testPVType.t ............ ok
> >>> testStandardField.t ..... ok
> >>> testStandardPVField.t ... ok
> >>> testPVData.t ............ ok
> >>> testPVUnion.t ........... ok
> >>> testConvert.t ........... ok
> >>> testPVScalarArray.t ..... ok
> >>> testPVStructureArray.t .. ok
> >>> testOperators.t ......... ok
> >>> testFieldBuilder.t ...... ok
> >>> testValueBuilder.t ...... ok
> >>> testProperty.t .......... ok
> >>> testCreateRequest.t ..... ok
> >>> testPVCopy.t ............ ok
> >>> Files=33, Tests=2248, 12 wallclock secs ( 0.50 usr +  0.06 sys =  0.56 CPU)
> >>> Result: PASS
> >>> testAtomicBoolean.t ..... ok
> >>> testHexDump.t ........... ok
> >>> testInetAddressUtils.t .. ok
> >>> configurationTest.t ..... ok
> >>> testFairQueue.t ......... ok
> >>> testWildcard.t .......... ok
> >>> testChannelAccess.t ..... ok
> >>> testCodec.t ............. ok
> >>> testRPC.t ............... ok
> >>> testServerContext.t ..... ok
> >>> Files=10, Tests=6192, 30 wallclock secs ( 0.44 usr +  0.01 sys =  0.45 CPU)
> >>> Result: PASS
> >>> ntfieldTest.t ............... ok
> >>> ntscalarTest.t .............. ok
> >>> ntscalarArrayTest.t ......... ok
> >>> ntnameValueTest.t ........... ok
> >>> ntmultiChannelTest.t ........ ok
> >>> ntscalarMultiChannelTest.t .. ok
> >>> nttableTest.t ............... ok
> >>> ntndarrayTest.t ............. ok
> >>> ntmatrixTest.t .............. ok
> >>> ntenumTest.t ................ ok
> >>> ntunionTest.t ............... ok
> >>> ntaggregateTest.t ........... ok
> >>> ntattributeTest.t ........... ok
> >>> ntndarrayAttributeTest.t .... ok
> >>> ntcontinuumTest.t ........... ok
> >>> nthistogramTest.t ........... ok
> >>> ntutilsTest.t ............... ok
> >>> Files=17, Tests=631,  3 wallclock secs ( 0.27 usr +  0.09 sys =  0.36 CPU)
> >>> Result: PASS
> >>> testPVCopy.t ......... ok
> >>> testPVRecord.t ....... ok
> >>> testExampleRecord.t .. ok
> >>> testLocalProvider.t .. ok
> >>> testPVAServer.t ...... ok
> >>> Files=5, Tests=81,  1 wallclock secs ( 0.06 usr +  0.03 sys =  0.09 CPU)
> >>> Result: PASS
> >>> testmon.t .. ok
> >>> Files=1, Tests=79,  0 wallclock secs ( 0.05 usr +  0.01 sys =  0.06 CPU)
> >>> Result: PASS
> >>> testweak.t .. ok
> >>> testtest.t .. ok
> >>> testpvif.t .. 1/71 Command stopPVAServer not found.
> >>> testpvif.t .. ok
> >>> testpdb.t ... ok
> >>> Files=4, Tests=247,  2 wallclock secs ( 0.08 usr +  0.05 sys =  0.12 CPU)
> >>> Result: PASS
> >>> This is for windows-x64-static
> >>> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64-static
> >>> Snippets.t .. ok
> >>> Files=1, Tests=29,  2 wallclock secs ( 0.03 usr +  0.00 sys =  0.03 CPU)
> >>> Result: PASS
> >>> epicsErrlogTest.t .......... 25/32 log client: connected to log server at "127.0.0.1:61307"
> >>> Test Summary Report
> >>> epicsMathTest.t          (Wstat: 0 Tests: 35 Failed: 0)
> >>>   TODO passed:   8-9, 11-12, 22-23
> >>> Files=40, Tests=4016, 204 wallclock secs ( 0.56 usr +  0.16 sys =  0.72 CPU)
> >>> Result: PASS
> >>>                                   {"x":bbbb}
> >>>                                        {"z":{"good":6}
> >>> dbServerTest.t ............. dbRegisterServer: 'one' registered twice?
> >>> dbServerTest.t ............. 1/24 dbRegisterServer: Bad server name 'bad name'
> >>> Files=20, Tests=2856, 82 wallclock secs ( 0.51 usr +  0.08 sys =  0.59 CPU)
> >>> Result: PASS
> >>> msi.t .. ok
> >>> Files=1, Tests=9,  0 wallclock secs ( 0.03 usr +  0.02 sys =  0.05 CPU)
> >>> Result: PASS
> >>> linkInitTest.t .......... 8/77 dbRegisterServer: 'rsrv' registered twice?
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>>                                       0x10
> >>> regressTest.t ........... 6/31 dbRegisterServer: 'rsrv' registered twice?
> >>> simmTest.t .............. Failed 3/1176 subtests
> >>> Test Summary Report
> >>> Result: FAIL
> >>> tsTest.t .... ok
> >>> dbndTest.t .. ok
> >>> arrTest.t ... ok
> >>> syncTest.t .. ok
> >>> Files=4, Tests=1612,  3 wallclock secs ( 0.19 usr +  0.00 sys =  0.19 CPU)
> >>> Result: PASS
> >>> Base.t ........ ok
> >>> Breaktable.t .. ok
> >>> DBD.t ......... ok
> >>> Device.t ...... ok
> >>> Driver.t ...... ok
> >>> Function.t .... ok
> >>> Menu.t ........ ok
> >>> Recfield.t .... ok
> >>> Recordtype.t .. ok
> >>> Registrar.t ... ok
> >>> Variable.t .... ok
> >>> Files=11, Tests=287,  1 wallclock secs ( 0.00 usr +  0.01 sys =  0.01 CPU)
> >>> Result: PASS
> >>> Files=33, Tests=2248, 294 wallclock secs ( 0.64 usr +  0.11 sys =  0.75 CPU)
> >>> Result: PASS
> >>> Files=10, Tests=6192, 28 wallclock secs ( 0.48 usr +  0.05 sys =  0.53 CPU)
> >>> Result: PASS
> >>> Files=17, Tests=631,  3 wallclock secs ( 0.14 usr +  0.08 sys =  0.22 CPU)
> >>> Result: PASS
> >>> Files=5, Tests=81,  2 wallclock secs ( 0.03 usr +  0.01 sys =  0.05 CPU)
> >>> Result: PASS
> >>> testmon.t .. ok
> >>> Result: PASS
> >>> testweak.t .. ok
> >>> testtest.t .. ok
> >>> testpvif.t .. ok
> >>> testpdb.t ... ok
> >>> Files=4, Tests=247,  4 wallclock secs ( 0.08 usr +  0.02 sys =  0.09 CPU)
> >>> Result: PASS
> >>> Mark
> >>> *From:*Mark Rivers
> >>> *Sent:* Friday, December 29, 2017 8:06 AM
> >>> *To:* Michael Davidsaver; 'Andrew Johnson'; '[email protected]'
> >>> *Subject:* Re: Problem building example application on windows-x64
> >>> I have tested the fixes.
> >>> I did the following in module/pvData and modules/pvAccess
> >>> git checkout master
> >>> git pull
> >>> Rebuilt base for windows-x64 and windows-x64-static.
> >>> Rebuilt example application for both ARCHs.
> >>> It appears to fix both problems:
> >>> - windows-x64 no longer hangs with WINSOCK errors when exiting.
> >>> - windows-x64-static no longer crashes on startup.
> >>> Thanks,
> >>> Mark
> >>> *From:*Michael Davidsaver <[email protected]
> >> <mailto:[email protected]>>
> >>> *Sent:* Thursday, December 28, 2017 12:23 PM
> >>> *To:* Mark Rivers; 'Andrew Johnson'; '[email protected]'
> >>> I have committed possible fixes for the first two issues.
> >>> On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
> >>>> So much for that.  I manged to miss this issue.  Time to open some tickets I think.
> >>>> So far I count four distinct symptoms, and the test failures.
> >>>> What I see so far:
> >>>> 1. Global ctor ordering issues needs to be opened against pvDataCPP and
> pvAccessCPP
> >>>>     (any probably others).
> >>> https://github.com/epics-base/pvDataCPP/issues/49
> >>> w/ candidate fix
> >>>> 2. The osiSockAttach() issue against pvAccessCPP.
> >>> https://github.com/epics-base/pvAccessCPP/issues/81
> >>> w/ candidate fix
> >>>> 3. The Com.res failure against Base (on launchpad)
> >>> https://bugs.launchpad.net/bugs/1740408
> >>>> 4. The timestamp issue w/ genVersionHeader.pl against Base
> >>> tbd.
Re: Problem building example application on windows-x64 Michael Davidsaver
Problem building example application on windows-x64 Mark Rivers
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Re: Problem building example application on windows-x64 Mark Rivers
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
Next: Re: Problem building example application on windows-x64 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
