On 12/30/2017 08:50 AM, Mark Rivers wrote:
> I have attached the .tap files. The first simmTest.tap is for windows-x64, the other files are all for windows-x64-static.
Thanks. I'll leave simmTest for Ralph.
>> And yet they show as PASS? Strange. Can you capture a couple of these?
> The dialog box gives options for Abort, Retry, and Ignore. I had selected Ignore which is probably why the test passed.
What message is shown? I'd guess something about NULL pointer.
I can't find a source listing, but it seems like the MSVC
implementation of std::equal() is being extra super helpful and
asserting that the third argument by non-NULL. In this case
it doesn't matter as the first two arguments are equal,
so the NULL is not dereferenced.
This raises a separate the question of whether std::equal() is
specified for an empty range, and what the results should be.
The consensus seems to be 'yes', and 'true', but I've not found
anything authoritative.
These issues arises when comparing empty shared_vector<>s.
Which currently return NULL for begin(), end(), and similar.
This seems like non-standard MSVC behavior, which I'd like to
understand more before attempting a workaround. The
possibilities are 1) make shared_vector return a non-NULL
pointers when empty(), or 2) refrain from calling
std::equal() on empty arrays.
> I now selected Retry which allows running the debugger. This is the stack trace for testSerialization:
>> testSerialization.exe!std::_Debug_message(const wchar_t * message=0x000000013f813048, const wchar_t * file=0x000000013f813080, unsigned int line=3049) Line 15 C++
> testSerialization.exe!std::_Debug_pointer<unsigned char>(const unsigned char * _First=0x0000000000000000, const wchar_t * _File=0x000000013f813080, unsigned int _Line=3049) Line 692 C++
> testSerialization.exe!std::equal<unsigned char const * __ptr64,unsigned char const * __ptr64>(const unsigned char * _First1=0x0000000000000000, const unsigned char * _Last1=0x0000000000000000, const unsigned char * _First2=0x0000000000000000) Line 3051 C++
> testSerialization.exe!epics::pvData::`anonymous namespace'::compareArray<unsigned char>(const epics::pvData::PVValueArray<unsigned char> * left=0x000000000028ade0, const epics::pvData::PVValueArray<unsigned char> * right=0x00000000002889d0) Line 159 + 0x4c bytes C++
> testSerialization.exe!epics::pvData::`anonymous namespace'::compareField(const epics::pvData::PVScalarArray * left=0x000000000028ade0, const epics::pvData::PVScalarArray * right=0x00000000002889d0) Line 202 + 0x15 bytes C++
> testSerialization.exe!epics::pvData::operator==(const epics::pvData::PVField & left={...}, const epics::pvData::PVField & right={...}) Line 339 + 0xf bytes C++
> testSerialization.exe!`anonymous namespace'::testEquals() Line 162 + 0x35 bytes C++
> testSerialization.exe!main(int __formal=1, int __formal=1) Line 875 C++
> testSerialization.exe!__tmainCRTStartup() Line 278 + 0x19 bytes C
> testSerialization.exe!mainCRTStartup() Line 189 C
> kernel32.dll!00000000775259cd()
> [Frames below may be incorrect and/or missing, no symbols loaded for kernel32.dll]
> ntdll.dll!000000007775a561()
> This is the stack trace for testPVScalarArray:
>> testPVScalarArray.exe!std::_Debug_message(const wchar_t * message=0x000000013f6a55d8, const wchar_t * file=0x000000013f6a4970, unsigned int line=3049) Line 15 C++
> testPVScalarArray.exe!std::_Debug_pointer<signed char>(const char * _First=0x0000000000000000, const wchar_t * _File=0x000000013f6a4970, unsigned int _Line=3049) Line 692 C++
> testPVScalarArray.exe!std::equal<signed char const * __ptr64,signed char const * __ptr64>(const char * _First1=0x0000000000000000, const char * _Last1=0x0000000000000000, const char * _First2=0x0000000000000000) Line 3051 C++
> testPVScalarArray.exe!epics::pvData::`anonymous namespace'::compareArray<signed char>(const epics::pvData::PVValueArray<signed char> * left=0x0000000000314260, const epics::pvData::PVValueArray<signed char> * right=0x0000000000314380) Line 159 + 0x4c bytes C++
> testPVScalarArray.exe!epics::pvData::`anonymous namespace'::compareField(const epics::pvData::PVScalarArray * left=0x0000000000314260, const epics::pvData::PVScalarArray * right=0x0000000000314380) Line 204 + 0x15 bytes C++
> testPVScalarArray.exe!epics::pvData::operator==(const epics::pvData::PVField & left={...}, const epics::pvData::PVField & right={...}) Line 339 + 0xf bytes C++
> testPVScalarArray.exe!`anonymous namespace'::testBasic<epics::pvData::PVValueArray<signed char> >() Line 93 + 0x2f bytes C++
> testPVScalarArray.exe!main(int __formal=1, int __formal=1) Line 206 C++
> testPVScalarArray.exe!__tmainCRTStartup() Line 278 + 0x19 bytes C
> testPVScalarArray.exe!mainCRTStartup() Line 189 C
> Mark
>> -----Original Message-----
>> From: Michael Davidsaver [mailto:[email protected]]
>> Sent: Friday, December 29, 2017 9:45 AM
>> To: Mark Rivers
>> Cc: 'Andrew Johnson'; '[email protected]'; Ralph Lange
>> Subject: Re: Problem building example application on windows-x64
>> On 12/29/2017 08:55 AM, Mark Rivers wrote:
>>> I have run the runtests for windows-x64 and windows-x64-staticon VS2010.
>>> For windows-x64 there were no dialog boxes.
>>> For windows-x64-static there were many Debug Assertion error dialog boxes in
>> testSerialization.t (24 times) and testPVScalarArrat (5 times)
>>> They all appear to be null pointer problems.
>> Maybe the first from each test for a start?
>>> Both also appeared to fail some tests:
>> At this point we need to see the output of the tests. Can you run:
>>> make tapfiles
>> Then collect the .tap files (test output) of the three mis-behaving tests.
>> These should be:
>> modules/database/test/std/O.*/simmTest.tap
>> modules/pvData/testApp/O.*/testSerialization.tap
>> modules/pvData/testApp/O.*/testPVScalarArray.tap
>>> These are failures on windows-x64:
>>> Test Summary Report
>>> simmTest.t (Wstat: 0 Tests: 1176 Failed: 7)
>>> Failed tests: 140, 315, 439-440, 665-666, 767
>>> Files=11, Tests=3575, 13 wallclock secs ( 0.48 usr + 0.08 sys = 0.56 CPU)
>>> Result: FAIL
>>> Failed 1/11 test programs. 7/3575 subtests failed.
>>> These are failures on windows-x64-static:
>>> Test Summary Report
>>> simmTest.t (Wstat: 0 Tests: 1176 Failed: 3)
>>> Failed tests: 355-356, 439
>>> Files=11, Tests=3575, 15 wallclock secs ( 0.50 usr + 0.03 sys = 0.53 CPU)
>>> Result: FAIL
>>> Failed 1/11 test programs. 3/3575 subtests failed.
>>> This is the output for windows-x64:
>>> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64
>>> H:\epics-devel\base-7.0.1>make -s runtests
>>> Snippets.t .. ok
>>> All tests successful.
>>> Files=1, Tests=29, 2 wallclock secs ( 0.05 usr + 0.00 sys = 0.05 CPU)
>>> Result: PASS
>>> epicsUnitTestTest.t ........ ok
>>> epicsTypesTest.t ........... ok
>>> epicsInlineTest.t .......... ok
>>> epicsCalcTest.t ............ ok
>>> epicsAlgorithmTest.t ....... ok
>>> epicsMathTest.t ............ ok
>>> epicsMMIOTest.t ............ ok
>>> epicsEllTest.t ............. ok
>>> epicsEnvTest.t ............. ok
>>> epicsErrlogTest.t .......... 24/32 log client: connected to log server at "127.0.0.1:60935"
>>> epicsErrlogTest.t .......... ok
>>> epicsStdioTest.t ........... ok
>>> epicsStdlibTest.t .......... ok
>>> epicsSockResolveTest.t ..... ok
>>> epicsStringTest.t .......... ok
>>> epicsTimeTest.t ............ ok
>>> epicsTimeZoneTest.t ........ ok
>>> epicsThreadTest.t .......... ok
>>> epicsThreadOnceTest.t ...... ok
>>> epicsThreadPriorityTest.t .. ok
>>> epicsThreadPrivateTest.t ... ok
>>> epicsThreadHooksTest.t ..... ok
>>> epicsThreadPoolTest.t ...... ok
>>> epicsExitTest.t ............ ok
>>> epicsTimerTest.t ........... ok
>>> ringPointerTest.t .......... ok
>>> ringBytesTest.t ............ ok
>>> epicsEventTest.t ........... ok
>>> epicsMutexTest.t ........... ok
>>> epicsSpinTest.t ............ ok
>>> epicsAtomicTest.t .......... ok
>>> macDefExpandTest.t ......... ok
>>> cvtFastTest.t .............. ok
>>> macLibTest.t ............... ok
>>> macLib.t ................... ok
>>> taskwdTest.t ............... ok
>>> blockingSockTest.t ......... ok
>>> epicsMessageQueueTest.t .... ok
>>> epicsStackTraceTest.t ...... ok
>>> ipAddrToAsciiTest.t ........ ok
>>> osiSockTest.t .............. ok
>>> Files=40, Tests=4016, 200 wallclock secs ( 0.56 usr + 0.16 sys = 0.72 CPU)
>>> Result: PASS
>>> dbScanTest.t ............... ok
>>> dbShutdownTest.t ........... ok
>>> dbPutLinkTest.t ............ 265/320 dbJLinkInit: lexical error: invalid char in json text.
>>> {"x":bbbb}
>>> (right here) ------^
>>> dbJLinkInit: parse error: premature EOF
>>> {"z":{"good":6}
>>> dbPutLinkTest.t ............ ok
>>> dbLockTest.t ............... ok
>>> dbStressTest.t ............. ok
>>> testdbConvert.t ............ ok
>>> callbackTest.t ............. ok
>>> callbackParallelTest.t ..... ok
>>> dbStateTest.t .............. ok
>>> dbServerTest.t ............. 1/24 dbRegisterServer: 'one' registered twice?
>>> dbRegisterServer: Bad server name 'bad name'
>>> dbRegisterServer: Ignoring 'disabled', per environment
>>> dbUnregisterServer: Servers still active!
>>> dbUnregisterServer: 'toolate' not registered.
>>> dbUnregisterServer: 'no-routines' has no stop() method.
>>> dbServerTest.t ............. ok
>>> dbCaStatsTest.t ............ ok
>>> dbCaLinkTest.t ............. ok
>>> scanIoTest.t ............... ok
>>> dbChannelTest.t ............ ok
>>> dbChArrTest.t .............. Starting iocInit
>>> iocRun: All initialization complete
>>> dbChArrTest.t .............. ok
>>> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
>>> chfPluginTest.t ............ ok
>>> arrShorthandTest.t ......... ok
>>> recGblCheckDeadbandTest.t .. ok
>>> testPutGetTest.t ........... ok
>>> dbStaticTest.t ............. ok
>>> Files=20, Tests=2856, 81 wallclock secs ( 0.41 usr + 0.11 sys = 0.51 CPU)
>>> Result: PASS
>>> msi.t .. ok
>>> Files=1, Tests=9, 1 wallclock secs ( 0.03 usr + 0.00 sys = 0.03 CPU)
>>> Result: PASS
>>> arrayOpTest.t ........... ok
>>> recMiscTest.t ........... ok
>>> linkRetargetLinkTest.t .. ok
>>> linkInitTest.t .......... 1/77 dbRegisterServer: 'rsrv' registered twice?
>>> linkInitTest.t .......... 18/77 dbRegisterServer: 'rsrv' registered twice?
>>> linkInitTest.t .......... 60/77 dbRegisterServer: 'rsrv' registered twice?
>>> linkInitTest.t .......... ok
>>> compressTest.t .......... 1/116 dbRegisterServer: 'rsrv' registered twice?
>>> compressTest.t .......... ok
>>> asyncSoftTest.t ......... ok
>>> softTest.t .............. ok
>>> asTest.t ................ ok
>>> analogMonitorTest.t ..... Starting iocInit
>>> analogMonitorTest.t ..... ok
>>> regressTest.t ........... 1/31 dbRegisterServer: 'rsrv' registered twice?
>>> dbConvertJSON: parse error: trailing garbage
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> regressTest.t ........... ok
>>> simmTest.t .............. Failed 7/1176 subtests
>>> Test Summary Report
>>> Result: FAIL
>>> tsTest.t .... ok
>>> dbndTest.t .. ok
>>> arrTest.t ... ok
>>> syncTest.t .. ok
>>> Files=4, Tests=1612, 3 wallclock secs ( 0.19 usr + 0.01 sys = 0.20 CPU)
>>> Result: PASS
>>> Base.t ........ ok
>>> Breaktable.t .. ok
>>> DBD.t ......... ok
>>> Device.t ...... ok
>>> Driver.t ...... ok
>>> Function.t .... ok
>>> Menu.t ........ ok
>>> Recfield.t .... ok
>>> Recordtype.t .. ok
>>> Registrar.t ... ok
>>> Variable.t .... ok
>>> Files=11, Tests=287, 1 wallclock secs ( 0.03 usr + 0.06 sys = 0.09 CPU)
>>> Result: PASS
>>> testThread.t ............ ok
>>> testEvent.t ............. ok
>>> testTimer.t ............. ok
>>> testBitSet.t ............ ok
>>> testOverrunBitSet.t ..... ok
>>> testByteBuffer.t ........ ok
>>> testBaseException.t ..... ok
>>> testSharedVector.t ...... ok
>>> testDebugPtr.t .......... ok
>>> testSerialization.t ..... ok
>>> testTimeStamp.t ......... ok
>>> testQueue.t ............. ok
>>> testTypeCast.t .......... ok
>>> testUnitTest.t .......... ok
>>> testjson.t .............. ok
>>> test_reftrack.t ......... ok
>>> testanyscalar.t ......... ok
>>> testBitSetUtil.t ........ ok
>>> testIntrospect.t ........ ok
>>> testPVType.t ............ ok
>>> testStandardField.t ..... ok
>>> testStandardPVField.t ... ok
>>> testPVData.t ............ ok
>>> testPVUnion.t ........... ok
>>> testConvert.t ........... ok
>>> testPVScalarArray.t ..... ok
>>> testPVStructureArray.t .. ok
>>> testOperators.t ......... ok
>>> testFieldBuilder.t ...... ok
>>> testValueBuilder.t ...... ok
>>> testProperty.t .......... ok
>>> testCreateRequest.t ..... ok
>>> testPVCopy.t ............ ok
>>> Files=33, Tests=2248, 12 wallclock secs ( 0.50 usr + 0.06 sys = 0.56 CPU)
>>> Result: PASS
>>> testAtomicBoolean.t ..... ok
>>> testHexDump.t ........... ok
>>> testInetAddressUtils.t .. ok
>>> configurationTest.t ..... ok
>>> testFairQueue.t ......... ok
>>> testWildcard.t .......... ok
>>> testChannelAccess.t ..... ok
>>> testCodec.t ............. ok
>>> testRPC.t ............... ok
>>> testServerContext.t ..... ok
>>> Files=10, Tests=6192, 30 wallclock secs ( 0.44 usr + 0.01 sys = 0.45 CPU)
>>> Result: PASS
>>> ntfieldTest.t ............... ok
>>> ntscalarTest.t .............. ok
>>> ntscalarArrayTest.t ......... ok
>>> ntnameValueTest.t ........... ok
>>> ntmultiChannelTest.t ........ ok
>>> ntscalarMultiChannelTest.t .. ok
>>> nttableTest.t ............... ok
>>> ntndarrayTest.t ............. ok
>>> ntmatrixTest.t .............. ok
>>> ntenumTest.t ................ ok
>>> ntunionTest.t ............... ok
>>> ntaggregateTest.t ........... ok
>>> ntattributeTest.t ........... ok
>>> ntndarrayAttributeTest.t .... ok
>>> ntcontinuumTest.t ........... ok
>>> nthistogramTest.t ........... ok
>>> ntutilsTest.t ............... ok
>>> Files=17, Tests=631, 3 wallclock secs ( 0.27 usr + 0.09 sys = 0.36 CPU)
>>> Result: PASS
>>> testPVCopy.t ......... ok
>>> testPVRecord.t ....... ok
>>> testExampleRecord.t .. ok
>>> testLocalProvider.t .. ok
>>> testPVAServer.t ...... ok
>>> Files=5, Tests=81, 1 wallclock secs ( 0.06 usr + 0.03 sys = 0.09 CPU)
>>> Result: PASS
>>> testmon.t .. ok
>>> Files=1, Tests=79, 0 wallclock secs ( 0.05 usr + 0.01 sys = 0.06 CPU)
>>> Result: PASS
>>> testweak.t .. ok
>>> testtest.t .. ok
>>> testpvif.t .. 1/71 Command stopPVAServer not found.
>>> testpvif.t .. ok
>>> testpdb.t ... ok
>>> Files=4, Tests=247, 2 wallclock secs ( 0.08 usr + 0.05 sys = 0.12 CPU)
>>> Result: PASS
>>> This is for windows-x64-static
>>> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64-static
>>> Snippets.t .. ok
>>> Files=1, Tests=29, 2 wallclock secs ( 0.03 usr + 0.00 sys = 0.03 CPU)
>>> Result: PASS
>>> epicsErrlogTest.t .......... 25/32 log client: connected to log server at "127.0.0.1:61307"
>>> Test Summary Report
>>> epicsMathTest.t (Wstat: 0 Tests: 35 Failed: 0)
>>> TODO passed: 8-9, 11-12, 22-23
>>> Files=40, Tests=4016, 204 wallclock secs ( 0.56 usr + 0.16 sys = 0.72 CPU)
>>> Result: PASS
>>> {"x":bbbb}
>>> {"z":{"good":6}
>>> dbServerTest.t ............. dbRegisterServer: 'one' registered twice?
>>> dbServerTest.t ............. 1/24 dbRegisterServer: Bad server name 'bad name'
>>> Files=20, Tests=2856, 82 wallclock secs ( 0.51 usr + 0.08 sys = 0.59 CPU)
>>> Result: PASS
>>> msi.t .. ok
>>> Files=1, Tests=9, 0 wallclock secs ( 0.03 usr + 0.02 sys = 0.05 CPU)
>>> Result: PASS
>>> linkInitTest.t .......... 8/77 dbRegisterServer: 'rsrv' registered twice?
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> 0x10
>>> regressTest.t ........... 6/31 dbRegisterServer: 'rsrv' registered twice?
>>> simmTest.t .............. Failed 3/1176 subtests
>>> Test Summary Report
>>> Result: FAIL
>>> tsTest.t .... ok
>>> dbndTest.t .. ok
>>> arrTest.t ... ok
>>> syncTest.t .. ok
>>> Files=4, Tests=1612, 3 wallclock secs ( 0.19 usr + 0.00 sys = 0.19 CPU)
>>> Result: PASS
>>> Base.t ........ ok
>>> Breaktable.t .. ok
>>> DBD.t ......... ok
>>> Device.t ...... ok
>>> Driver.t ...... ok
>>> Function.t .... ok
>>> Menu.t ........ ok
>>> Recfield.t .... ok
>>> Recordtype.t .. ok
>>> Registrar.t ... ok
>>> Variable.t .... ok
>>> Files=11, Tests=287, 1 wallclock secs ( 0.00 usr + 0.01 sys = 0.01 CPU)
>>> Result: PASS
>>> Files=33, Tests=2248, 294 wallclock secs ( 0.64 usr + 0.11 sys = 0.75 CPU)
>>> Result: PASS
>>> Files=10, Tests=6192, 28 wallclock secs ( 0.48 usr + 0.05 sys = 0.53 CPU)
>>> Result: PASS
>>> Files=17, Tests=631, 3 wallclock secs ( 0.14 usr + 0.08 sys = 0.22 CPU)
>>> Result: PASS
>>> Files=5, Tests=81, 2 wallclock secs ( 0.03 usr + 0.01 sys = 0.05 CPU)
>>> Result: PASS
>>> testmon.t .. ok
>>> Result: PASS
>>> testweak.t .. ok
>>> testtest.t .. ok
>>> testpvif.t .. ok
>>> testpdb.t ... ok
>>> Files=4, Tests=247, 4 wallclock secs ( 0.08 usr + 0.02 sys = 0.09 CPU)
>>> Result: PASS
>>> Mark
>>> *From:*Mark Rivers
>>> *Sent:* Friday, December 29, 2017 8:06 AM
>>> *To:* Michael Davidsaver; 'Andrew Johnson'; '[email protected]'
>>> *Subject:* Re: Problem building example application on windows-x64
>>> I have tested the fixes.
>>> I did the following in module/pvData and modules/pvAccess
>>> git checkout master
>>> git pull
>>> Rebuilt base for windows-x64 and windows-x64-static.
>>> Rebuilt example application for both ARCHs.
>>> It appears to fix both problems:
>>> - windows-x64 no longer hangs with WINSOCK errors when exiting.
>>> - windows-x64-static no longer crashes on startup.
>>> Thanks,
>>> Mark
>>> *From:*Michael Davidsaver <[email protected]
>> <mailto:[email protected]>>
>>> *Sent:* Thursday, December 28, 2017 12:23 PM
>>> *To:* Mark Rivers; 'Andrew Johnson'; '[email protected]'
>>> I have committed possible fixes for the first two issues.
>>> On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
>>>> So much for that. I manged to miss this issue. Time to open some tickets I think.
>>>> So far I count four distinct symptoms, and the test failures.
>>>> What I see so far:
>>>> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
>>>> (any probably others).
>>> https://github.com/epics-base/pvDataCPP/issues/49
>>> w/ candidate fix
>>>> 2. The osiSockAttach() issue against pvAccessCPP.
>>> https://github.com/epics-base/pvAccessCPP/issues/81
>>> w/ candidate fix
>>>> 3. The Com.res failure against Base (on launchpad)
>>> https://bugs.launchpad.net/bugs/1740408
>>>> 4. The timestamp issue w/ genVersionHeader.pl against Base
>>> tbd.
signature.asc
Description: OpenPGP digital signature
- RE: Problem building example application on windows-x64 Mark Rivers
- Re: Problem building example application on windows-x64 Ralph Lange
- Problem building example application on windows-x64 Mark Rivers
- Re: Problem building example application on windows-x64 Andrew Johnson
- Re: Problem building example application on windows-x64 Michael Davidsaver
- Re: Problem building example application on windows-x64 Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
