2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Error message binding socket 5076 on vxWorks
From: "Heinz P. Junkes via Core-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 13 Jan 2020 17:28:22 +0100
libComTestHarness with rtems-5.0.0-m1912
and rtems-libbsd-5.0.0-m1912
ok  5 - setsockopt BROADCAST := 0
ok  6 - getsockopt BROADCAST => 0
ok  7 - setsockopt MULTICAST_LOOP := 1
ok  8 - getsockopt MULTICAST_LOOP => 1
ok  9 - setsockopt MULTICAST_LOOP := 0
ok 10 - getsockopt MULTICAST_LOOP => 0
ok 11 - setsockopt IP_MULTICAST_TTL := 1
ok 12 - getsockopt IP_MULTICAST_TTL => 1
ok 13 - setsockopt IP_MULTICAST_TTL := 0
ok 14 - getsockopt IP_MULTICAST_TTL => 0
# First test if epicsSocketEnableAddressUseForDatagramFanout() is necessary
ok 15 - bind() to port 50287
ok 16 - bind() to 50287 error -1, 112
# Now the real test
ok 17 - bind() to port 50287
ok 18 - bind() to port 50287
    Results
       Tests: 18
      Passed:  18 = 100.00%
Heinz
On 1/12/20 9:10 PM, Michael Davidsaver wrote:
On 1/12/20 9:50 AM, Michael Davidsaver wrote:
While I would expect this would have been noticed before now,
one possibility is that SO_REUSEADDR doesn't have the desired effect
on vxWorks.  At least not for UDP sockets.
Maybe not as far fetched as I had thought.  It seems that this has been
the case for RTEMS 4.9/4.10.  I found an old email from Heinz reporting
what seems like a similar issue in 2016 (sorry Heinz, I guess this was
dropped).
There is no test coverage, and CA has never needed it to work on this OS.
A test case seems like the right place to start.  If you update to
the 7.0 branch from my github repo
https://github.com/mdavidsaver/epics-base/tree/7.0
I've extended osiSockTest:
ok 15 - bind() to port 47435
ok 16 - bind() to 47435 error -1, 98
# Now the real test
ok 17 - bind() to port 47435
ok 18 - bind() to port 47435
I'd be interested to know if this passes for you (or Andrew when he reads this) on vxWorks.
osiSockTest is part of the libCom test harness if that's easier
for you to run.
The change I've made is to prefer SO_REUSEPORT on those targets,
excepting windows/cygwin, which define it.  Google gives some hints
that this includes vxWorks.
Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Prev: Re: Error message binding socket 5076 on vxWorks Heinz Junkes via Core-talk
Next: Build failed: epics-base base-7.0-388 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Build failed: epics-base base-integration-387 AppVeyor via Core-talk
ANJ, 13 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
