2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: AW: AW: AW: AW: Problems with hanging osiSockTest
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, Ralph Lange <ralph.lange at gmx.de>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Mon, 23 Nov 2020 09:39:58 +0100
Working from home ?
On 11/23/20 9:28 AM, Zimoch Dirk (PSI) via Core-talk wrote:
Me compiling EPICS 7:
https://image.shutterstock.com/image-vector/cartoon-caveman-using-laptop-vector-260nw-327170621.jpg <https://image.shutterstock.com/image-vector/cartoon-caveman-using-laptop-vector-260nw-327170621.jpg>
*Von:*Core-talk <core-talk-bounces at aps.anl.gov> *Im Auftrag von *Ralph Lange via Core-talk
*Gesendet:* Freitag, 20. November 2020 17:14
*An:* EPICS Core Talk <core-talk at aps.anl.gov>
*Betreff:* Re: AW: AW: AW: Problems with hanging osiSockTest
Neolithic vxWorks (5.x?) is the only one I know, and I know that Dirk uses.
Andrew always fixed these situations in Base, but he stopped doing that. When APS moved to vxWorks 6? Around Bronze age?
Cheers,
~Ralph
On Fri, 20 Nov 2020 at 16:42, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
    On 11/20/20 12:49 AM, Zimoch Dirk (PSI) wrote:
     > Which this change, the tests terminates and succeeds.
     > Please do not have variable declarations after instructions in C
    (non C++) code. Not all compilers like that. I already had to fix
    udpSockFanoutTestRx() because of this problem:
    How could we expand our CI coverage to discover this?
    Do your CI builds cover this case?  (a non-MS compiler
    which still imposes this C89 ordering restriction by
    default)
     > @@ -213,6 +213,7 @@ void udpSockFanoutTestRx(void* raw)
     >      struct TInfo *info = raw;
     >      epicsTimeStamp start, now;
     > +    unsigned nremain = nrepeat;
     >  #ifdef _WIN32
     >      /* ms */
     >      DWORD timeout = 10000;
     > @@ -222,7 +223,6 @@ void udpSockFanoutTestRx(void* raw)
     >      timeout.tv_sec = 10;
     >      timeout.tv_usec = 0;
     >  #endif
     > -    unsigned nremain = nrepeat;
     >      (void)epicsTimeGetCurrent(&start);
     >      now = start;
     > Dirk
     >> -----Ursprüngliche Nachricht-----
     >> Von: Michael Davidsaver <mdavidsaver at gmail.com
    <mailto:mdavidsaver at gmail.com>>
     >> Gesendet: Donnerstag, 19. November 2020 19:24
     >> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch
    <mailto:dirk.zimoch at psi.ch>>
     >> Cc: Johnson, Andrew N. <anj at anl.gov <mailto:anj at anl.gov>>; EPICS
    core-talk <core-
     >> talk at aps.anl.gov <mailto:talk at aps.anl.gov>>
     >> Betreff: Re: AW: AW: Problems with hanging osiSockTest
     >> On 11/19/20 2:27 AM, Zimoch Dirk (PSI) wrote:
     >>> I have tested the latest 7.0 commit.
     >>> osiSockTest still hangs on the virbr0 interface:
     >> Ha.  I see why my attempt to have this test timeout is broken.
     >>> diff --git a/modules/libcom/test/osiSockTest.c
     >> b/modules/libcom/test/osiSockTest.c
     >>> index e71eec5fe..a3b831b66 100644
     >>> --- a/modules/libcom/test/osiSockTest.c
     >>> +++ b/modules/libcom/test/osiSockTest.c
     >>> @@ -239,6 +239,8 @@ void udpSockFanoutTestRx(void* raw)
     >>>          osiSockAddr src;
     >>>          osiSocklen_t srclen = sizeof(src);
     >>> +        (void)epicsTimeGetCurrent(&now);
     >>>          int n = recvfrom(info->sock, buf.bytes,
    sizeof(buf.bytes), 0, &src.sa <http://src.sa>,
     >> &srclen);
     >>>          buf.bytes[sizeof(buf.bytes)-1] = '\0';
Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Re: AW: AW: AW: Problems with hanging osiSockTest Ralph Lange via Core-talk
AW: AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Prev: Re: New Travis CI pricing model Jeong Han Lee via Core-talk
Next: How to "tweek" tests? Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: AW: AW: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Next: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
ANJ, 23 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
