2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Problem with huge waveforms in EPICS 7
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "mdavidsaver at gmail.com" <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Thu, 30 Jun 2022 06:59:32 +0000
On Wed, 2022-06-29 at 10:34 -0700, Michael Davidsaver wrote:
> On 6/28/22 00:13, Zimoch Dirk (PSI) wrote:
> > Confirmed with my test setup.
> Applied as https://github.com/epics-base/epics-base/commit/4df48c91f4e7202899bd859312a2b68148bf0bad
> I also made a note on the PR
> https://github.com/epics-base/epics-base/pull/99#discussion_r910230977
Thanks!
This issue has shown one of the limitations of the ci tests as we have them now: The problem only shows when ioc and
client run on two different hosts, so that network bandwidth is an issue.
Is there any way to cover such cases in the test environments?
Dirk
Re: Problem with huge waveforms in EPICS 7 Ralph Lange via Core-talk
Re: Problem with huge waveforms in EPICS 7 Michael Davidsaver via Core-talk
Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
Re: Problem with huge waveforms in EPICS 7 Andrew Johnson via Core-talk
Re: Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
RE: Problem with huge waveforms in EPICS 7 Mark Rivers via Core-talk
Prev: Build completed: epics-base base-iocsh-complete-865 AppVeyor via Core-talk
Next: Re: Problem with huge waveforms in EPICS 7 Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Problem with huge waveforms in EPICS 7 Michael Davidsaver via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
