On 6/29/22 23:59, Zimoch Dirk (PSI) wrote:
On Wed, 2022-06-29 at 10:34 -0700, Michael Davidsaver wrote:
On 6/28/22 00:13, Zimoch Dirk (PSI) wrote:
Confirmed with my test setup.
Applied as https://github.com/epics-base/epics-base/commit/4df48c91f4e7202899bd859312a2b68148bf0bad
I also made a note on the PR
https://github.com/epics-base/epics-base/pull/99#discussion_r910230977
Thanks!
This issue has shown one of the limitations of the ci tests as we have them now: The problem only shows when ioc and
client run on two different hosts, so that network bandwidth is an issue.
Is there any way to cover such cases in the test environments?
A more tractable problem would be testing the overflow behavior of dbEvent.
I think this could be accomplished by causing a callback set via
db_add_extra_labor_event() to block on an epicsEvent to prevent the queue
from emptying. Then post events until the queue overflows. Then trigger
the epicsEvent, and allow the queue to empty.
- Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Andrew Johnson via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Michael Davidsaver via Core-talk
- RE: Problem with huge waveforms in EPICS 7 Mark Rivers via Core-talk
Re: Problem with huge waveforms in EPICS 7 Ralph Lange via Core-talk
Build failed: EPICS Base 7 base-7.0-611 AppVeyor via Core-talk
<2022>
2025
2026
Re: Problem with huge waveforms in EPICS 7 Mark Rivers via Core-talk
<2022>
2025
2026
