2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: epics-base/.ci submodule problem
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "anj at anl.gov" <anj at anl.gov>, "mdavidsaver at gmail.com" <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 2 Aug 2022 08:08:33 +0000
When I cloned base 7.0 for my JSONerrors branch a few days ago, I noticed the problem with .ci:
$ git status
#	modified:   .ci (new commits, modified content)
and also noticed that the referenced commit did not exist.
$ git submodule update
fatal: reference is not a tree: 8a2666a9deeb6c618bcc73ba80f1a83a878c7a84
Unable to checkout '8a2666a9deeb6c618bcc73ba80f1a83a878c7a84' in submodule path '.ci'
But it did not really hinder my work or stop me from cloning it. It just showed the error.
My git version is 1.8.3.1.
Dirk
On Mon, 2022-08-01 at 10:56 -0700, Michael Davidsaver via Core-talk wrote:
> On 8/1/22 10:51, Andrew Johnson wrote:
> > Thanks, that seems to have fixed it (after blowing away the agent's workspaces again).
> > No idea why it succeeded on MacOS before that, the git version there is a bit older than the one on the RHEL-7
> > (linux-64) build agent.
> > Should we be protecting our submodule master branches from force-pushes?
> Yes.  I've been trying to remember to enable protection for
> repositories I've created recently.
> > GitHub can do that now IIRC. A discussion topic for Wednesday I think...
> I've gone ahead and done this for the github.com/epics-base
> repositories I ~regularly push to.  Launchpad remains an open
> items...
> > - Andrew
> > On 8/1/22 12:30 PM, Michael Davidsaver wrote:
> > > On 8/1/22 10:21, Andrew Johnson via Core-talk wrote:
> > > > APS Jenkins seems to be unable to clone the epics-base repo (I'm not sure why that just succeeded on macOS,
> > > > which is running exactly the same commands as the Linux agents) due to something in the .ci submodule.
> > > It looks like there was a force push to 'master' in ci-scripts
> > > some time on or after the 24th.  ("origin/master" in my checkout
> > > was still pointing to the g8a2666a rev.)
> > > So as not to have a dangling submodule reference in the Base history
> > > I have created a tag "v3.3.0-10-g8a2666a" to keep that rev. reachable.
> > > > On 8/1/22 11:56 AM, APS Jenkins via Core-talk wrote:
> > > > > Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/413/
> > > > > This job failed to build.
> > > > >  > git config --get submodule.modules/pvDatabase.url # timeout=10
> > > > >  > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
> > > > >  > git config --get submodule.modules/pva2pva.url # timeout=10
> > > > >  > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
> > > > >  > git config --get submodule..ci.url # timeout=10
> > > > >  > git config -f .gitmodules --get submodule..ci.path # timeout=10
> > > > > Setting http proxy: webproxy1.anl.gov:9091
> > > > >  > git submodule update modules/pvData # timeout=10
> > > > >  > git submodule update modules/pvAccess # timeout=10
> > > > >  > git submodule update modules/normativeTypes # timeout=10
> > > > >  > git submodule update modules/pvaClient # timeout=10
> > > > >  > git submodule update modules/pvDatabase # timeout=10
> > > > >  > git submodule update modules/pva2pva # timeout=10
> > > > >  > git submodule update .ci # timeout=10
> > > > > hudson.plugins.git.GitException: Command "git submodule update .ci" returned status code 1:
> > > > > stdout: Cloning into '.ci'...
> > > > > stderr: fatal: reference is not a tree: 8a2666a9deeb6c618bcc73ba80f1a83a878c7a84
> > > > I'm guessing we may just need to commit a 'git add .ci; git commit' to the 7.0 branch to fix that but I'm not
> > > > certain, can someone explain what happened to the ci submodule?
> > > > - Andrew
> > > > Complexity comes for free, Simplicity you have to work for.
Re: epics-base/.ci submodule problem Ralph Lange via Core-talk
epics-7.0 » linux64 - Build # 412 - Failure! APS Jenkins via Core-talk
epics-7.0 » linux64 - Build # 413 - Still Failing! APS Jenkins via Core-talk
epics-base/.ci submodule problem Andrew Johnson via Core-talk
Re: epics-base/.ci submodule problem Michael Davidsaver via Core-talk
Re: epics-base/.ci submodule problem Andrew Johnson via Core-talk
Prev: epics-7.0 » linux32 - Build # 415 - Still unstable! APS Jenkins via Core-talk
Next: Re: epics-base/.ci submodule problem Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: epics-base/.ci submodule problem Michael Davidsaver via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
