2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: STATIC_BUILD=NO howto ?
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 13 Jun 2023 13:07:53 +0000
Thanks Mark and Ralph.
This line is all that is needed:
  ethercatmc_SYS_LIBS += Vendor
/Torsten
Date: Tuesday, 13 June 2023 at 15:03
To: Torsten Bögershausen <Torsten.Bogershausen at ess.eu>, Ralph Lange <ralph.lange at gmx.de>
Hi Torsten and Ralph,
  • Btw. I should have mentioned before: You only need to add the *_DIR line if the library is not in one of the system paths. Libraries in system paths are always found - adding them to *_LIBS is enough.
Actually if the library is in the system path then it needs to be added to SYS_LIBS, not _LIBS.
This is an example of a Makefile that allows the vendor library to either be in a system location or in a user-defined location.  The latter might be used when the developer does not have permission to install the vendor library into a system location, or wants to test a newer version than the one in the system location:
CONFIG_SITE contains these lines:
# Set this if the Measurement Computing uldaq library is installed on Linux.
# If this is not YES then this module will not be built on Linux.
HAVE_ULDAQ=YES
# If libuldaq on Linux is not installed in a system directory (e.g. /usr/local)
# then uncomment and edit these lines to define the location of the include and lib directories.
#ULDAQ_DIR=/home/epics/local/lib
#ULDAQ_INCLUDE=/home/epics/local/include
The Makefile contains these lines:
ifdef ULDAQ_INCLUDE
  USR_INCLUDES_Linux += -I$(ULDAQ_INCLUDE)
endif
ifdef ULDAQ_DIR
  uldaq_DIR = $(ULDAQ_DIR)
endif
ifeq ($(HAVE_ULDAQ), YES)
  LIBRARY_IOC_Linux+= measComp
endif
ifdef ULDAQ_DIR
  measCompApp_LIBS_Linux += uldaq
else
  measCompApp_SYS_LIBS_Linux += uldaq
endif
measCompApp_SYS_LIBS_Linux += usb-1.0
So if ULDAQ_DIR is defined then it adds uldaq to LIBS. If ULDAQ_DIR is not defined then it adds uldaq to SYS_LIBS.
It handles Linux and Windows separately because the vendor provides a pre-built library for Windows which I include in the EPICS module, but they provide source code on Linux which needs to be built locally.  That can be installed into a system directory or not depending on developer privileges.
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Core-talk <core-talk at aps.anl.gov>
Sent: Tuesday, June 13, 2023 7:25 AM
Well,
In that Makefile, the PROD is "ethercatmc", not "ethercatmcsupport".
ethercatmc_LIBS += Vendor
Vendor_DIR = /usr/local/lib
should construct the linker line as you expect.
Cheers,
~Ralph
Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Re: STATIC_BUILD=NO howto ? Mark Rivers via Core-talk
Prev: Re: STATIC_BUILD=NO howto ? Mark Rivers via Core-talk
Next: Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 14 Jun 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
