2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: STATIC_BUILD=NO howto ?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 14 Jun 2023 11:08:28 +0200
  • Btw. I should have mentioned before: You only need to add the *_DIR line if the library is not in one of the system paths. Libraries in system paths are always found - adding them to *_LIBS is enough.
Actually if the library is in the system path then it needs to be added to SYS_LIBS, not _LIBS.
That is correct, of course. My bad.
Note that for _LIBS, Make does the linker line extensions based on wildcard expressions in the file system (see RULES_TARGET in Base), which means that the linker line only gets extended correctly if the library with the specified name is found in the specified place. Having a typo in the _DIRS setting (or the library in a different location, like in .../lib64 instead of .../lib) may have that library not show up correctly in the linker command.
Libraries in _SYS_LIBS are added to the linker line without Make checking for their existence, assuming the linker will find them.
Glad you have it working.
~Ralph
STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Re: STATIC_BUILD=NO howto ? Mark Rivers via Core-talk
Prev: Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Next: Build failed: epics-base base-integration-964 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 14 Jun 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
