Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 19:40:02 +0000
Hi Lewis,
On Jun 18, 2020, at 2:24 PM, J. Lewis Muir <[email protected]> wrote:
On 06/18, Johnson, Andrew N. via Tech-talk wrote:
It’s a risk, but screen has been an essential part of our systems since we started using soft IOCs without our hitting that issue to my knowledge. I don’t have an alternative solution, I assume tmux might behave the same?
If you're asking whether tmux can log, the answer is yes, using the
pipe-pane command.
No, I’m asking what tmux does if you run an IOC in it that generates messages occasionally, then use the ability to look back in its scroll-back buffer and leave your window scrolled to the very beginning of the buffer for a long time after the buffer has reached its size limit. Does it eventually freeze the IOC by imposing flow-control on the stdout/stderr stream from the IOC?
That was the problem that GNU Screen apparently has which triggered the writing of procServ.
Eric, you would probably never leave a Screen session in that state yourself, but please give it a go if you have time...
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly Jeong Han Lee via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Next: new version for CA Lab (EPICS <-> LabVIEW interface) 1.7.0.1 Carsten Winkler via Tech-talk
Next: Re: How to run IOC in docker containers properly Jeong Han Lee via Tech-talk
