1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Multiple IOCs on one host Issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Date: Fri, 19 Mar 2021 18:47:03 +0000
Nm my stupidity, I was looking at the wrong iptables (filter) not the nat table.  I will test this out now on our main system and see if it solves the issue of multiple IOCs.  Still need to figure out why the grep is not working correctly though.
Sent: Friday, March 19, 2021 11:44 AM
To: Manoussakis, Adamandios <[email protected]>; Ralph Lange <[email protected]>
Cc: [email protected]
So I just hardcoded in addr/bcast to see if the rest of the script would function correctly and now it gets down to the iptables command that sets up the rules.  But when I check sudo iptables -L -v -n I am not seeing it added for some reason.
jetson@ubuntu:/etc/network/if-up.d$ sudo ifup ens33
Internet Systems Consortium DHCP Client 4.3.5
Copyright 2004-2016 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/ens33/00:0c:29:c6:6f:a0
Sending on   LPF/ens33/00:0c:29:c6:6f:a0
Sending on   Socket/fallback
DHCPDISCOVER on ens33 to 255.255.255.255 port 67 interval 3 (xid=0xe228736a)
DHCPREQUEST of 192.168.252.132 on ens33 to 255.255.255.255 port 67 (xid=0x6a7328e2)
DHCPOFFER of 192.168.252.132 from 192.168.252.254
DHCPACK of 192.168.252.132 from 192.168.252.254
cmp: EOF on /tmp/tmp.nKI1m7I1fj which is empty
/sbin/dhclient-script: 8: /etc/dhcp/dhclient-exit-hooks.d/chrony: /usr/lib/chrony/chrony-helper: not found
bound to 192.168.252.132 -- renewal in 889 seconds.
+ PORT=5064
+ [ dhcp != none ]
+ [ ens33 != lo ]
+ ip addr show ens33
+ line=2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff
    inet 192.168.252.132/24 brd 192.168.252.255 scope global ens33
       valid_lft forever preferred_lft forever
    inet6 fe80::20c:29ff:fec6:6fa0/64 scope link tentative
+ addr=192.168.252.132
+ bcast=192.168.252.255
+ [ -z 192.168.252.132 -o -z 192.168.252.255 ]
+ [ start = start ]
+ iptables -t nat -A PREROUTING -d 192.168.252.132 -p udp --dport 5064 -j DNAT --to-destination 192.168.252.255
+ exit 0
jetson@ubuntu:/etc/network/if-up.d$ sudo iptables -L -v -n
Chain INPUT (policy ACCEPT 381K packets, 587M bytes)
pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
    0     0 DOCKER-USER  all  --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 DOCKER-ISOLATION-STAGE-1  all  --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     all  --  *      docker0  0.0.0.0/0            0.0.0.0/0            ctstate RELATED,ESTABLISHED
    0     0 DOCKER     all  --  *      docker0  0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     all  --  docker0 !docker0  0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     all  --  docker0 docker0  0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 192K packets, 17M bytes)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
    0     0 DOCKER-ISOLATION-STAGE-2  all  --  docker0 !docker0  0.0.0.0/0            0.0.0.0/0
    0     0 RETURN     all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
    0     0 DROP       all  --  *      docker0  0.0.0.0/0            0.0.0.0/0
Chain DOCKER-USER (1 references)
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Friday, March 19, 2021 11:25 AM
To: Ralph Lange <[email protected]>; 'Ralph Lange' <[email protected]>
Thanks Heinz,
I seem to be still getting the return error from Ralph’s script even with the changes below that you mentioned. I did have to add the closing quotations on the last grep commands for addr/bcast, I was getting unterminated string error.
line=`ip addr show $IFACE`
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
[ -z "$addr" -o -z "$bcast" ] && return 1
@Ralph
Here is what the script is going through, seems like the grep is still failing
jetson@ubuntu:/etc/network/if-up.d$ sudo sh -x ioc.sh
+ PORT=5064
+ [  != none ]s
+ [  != lo ]
+ ip addr show
+ line=1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
    link/ether 02:42:6a:5e:1a:03 brd ff:ff:ff:ff:ff:ff
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
+ echo 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff inet 192.168.252.132/24 brd 192.168.252.255 scope global ens33 valid_lft forever preferred_lft forever inet6 fe80::20c:29ff:fec6:6fa0/64 scope link valid_lft forever preferred_lft forever 3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default link/ether 02:42:6a:5e:1a:03 brd ff:ff:ff:ff:ff:ff inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0 valid_lft forever preferred_lft forever
+ grep -Po inet\s+[^\s]+\s+
+ grep -Po \d+.*’
+ addr=
+ grep -Po \d+.*’
+ grep -Po brd\s+[^\s]+\s+
+ bcast=
+ [ -z  -o -z  ]
+ return 1
From: Tech-talk [email protected] On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, March 19, 2021 9:35 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Multiple IOCs on one host Issue
On Fri, 19 Mar 2021 at 10:59, Heinz Junkes <[email protected]> wrote:
The right expressions might be these ones:
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’`
Impressive.
Do these work with older systems - where the other expressions worked?
Cheers,
~Ralph
Re: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Re: Multiple IOCs on one host Issue Heinz Junkes via Tech-talk
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: Re: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
