On 11/29/23 09:55, J. Lewis Muir wrote:
On 11/29, Michael Davidsaver wrote:
On 11/28/23 21:19, J. Lewis Muir via Tech-talk wrote:
What C language standard (e.g., C99) and C++ language standard
(e.g., C++11) does EPICS 7 Base require?
Currently epics-base and the bundled PVA modules should build with -std=c++98.
Thanks! And what about C?
In practice, my answer is the same. The toolchains we test with.
eg. RTEMS 4.9 has GCC 4.4.
On "paper" C89. I am less certain that Base would actually build with
-std=c89 as we may use some compiler specific features in OS/compiler
specific code.
Also, is there a C and C++ language standard for EPICS 7 modules?
BTW, the EPICS 7 Base build system does not specify a C and C++ standard
when compiling (e.g., via a "-std=" compiler option) on most platforms,
but I think it should on all platforms. I only see that compiler option
being used in the following:
Of more practical importance than -std=... we test with older G++ and MSVC.
eg. with my PVXS modules, while I say >= c++11. In practice my compatibility
target is g++ >= 4.8 (circa RHEL7) which implemented most, but not all, of c++11.
Thanks! And again, what about C?
PVXS is written in C++.
- Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
- C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
- Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
RE: Simulated limit switches on motorSim motor Mark Rivers via Tech-talk
Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
<2023>
<2023>
