1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm handler confusion (and solution)
To: [email protected]
Date: Wed, 29 Aug 2001 07:50:37 -1000
[email protected] wrote:
>   >> > It appears that the cut-off in the addressing is not in the mail
>   >> > forwarding but in the alarm handler reading its configuration file.
>   >> > What is the limit on the line length in alarm handler config files?
>   >> Oops,
>   >> the config file line length is limited by a buffer which is of length
>   >> MAX_STRING_LENGTH, i.e. 500 (defined in alh.h).
>   > the line length was definitely below 200 characters at all times.
>   > I don't know whether I exceeded 2 lines (wrapped) at some point in
>   > time.
> Hi Maren,
> I dug through the CVS repository and found out that the line length was
> increased from 150 to 500 characters with revision 1.9 on 1998/08/03.
> If you are using an antique version of alh (with alh.h being older than
> revision 1.9) any input line will be truncated at 149 characters - this
> would fit your problem, right?
yup. did too, ours was dated of some time in 1997.
Found quite a few other improvements too.
Question: I put
alh -filter a -s <config file>
and it runs without beeping ok. The way I understand the documentation
the "- filter a" should make the blinking of alarms go away when
the alarms are no longer active. Am I understanding this wrong or
did I write the command line wrong? This would be nice to have
because we run several alarm handlers and it would be nice to just
look at one screen and know if there are alarms that are still
active.
Maren
Re: alarm handler confusion (and solution) Ralph . Lange
Re: alarm handler confusion (and solution) Janet Anderson
alarm handler confusion (and solution) Maren Purves
Re: alarm handler confusion (and solution) Maren Purves
Prev: Re: CapFast Linux version ROBERT F SMYTHE
Next: AllenBradley PLC via ethernet Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm handler confusion (and solution) Ralph . Lange
Next: Re: alarm handler confusion (and solution) Ralph . Lange
