Hi Matt,
as Andrew covered the technical aspects and pointed out solutions, I
just want to clarify:
In your original mail, you sounded as you were assuming that the
environment variable EPICS_CA_MAX_ARRAY_BYTES was introduced with the
intention of limiting the size of arrays that CA is able to handle.
My statement was: No, it was the other way round. The limitation had
been there from the beginning. The environment variable was introduced
with the intention to overcome this limitation and allow CA to handle
larger arrays.
Sorry for being not clear enough in the first place.
Cheers,
Ralph
On Thu 27 May 2010 21:25:01 Matt Newville wrote:
Hi Ralph,
Thanks for the reply.
On Wed, May 26, 2010 at 11:27 AM, Ralph Lange <[email protected]> wrote:
Hi Matt,
nope, it's the other way round:
Maybe I'm still not understanding completely because I don't see much
difference between your explanation and what I said,
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
- labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
- RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Ralph Lange
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Andrew Johnson
Fall Epics Meeting location? Jane Richards
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
