Glad it's working, but I don't understand the problem, because asyn
R4-10 should also work fine.
-----Original Message-----
Sent: Wednesday, June 16, 2010 11:00 AM
To: Mark Rivers
Cc: Ralph Lange; [email protected]
Subject: Re: Channel Access Writes Failed on Asyn Record Writable Fields
I finally got it working. The problem turned out to be that there is
something wrong with the asyn library my code was linking to. After I
linked my code to a different asyn library (R4-13), the asynRecord is
working. Thank you very much for your help. I really appreciate it.
William
Mark Rivers wrote:
> Note that DSET=(nil) and RSET=(nil). That is wrong.
> It looks to me like the record was not initialized correctly. Did you
> get errors in iocInit?
> Mark
> From: William Lu [mailto:[email protected]]
> Sent: Wednesday, June 16, 2010 10:04 AM
> To: Mark Rivers
Fields
> Here is what I got. By the way, I am using asyn version R4-10.
> epics> dbpf LS450PS:asyn "test"
> filename="../dbTest.c" line number=295
> putFields are disabled - dbPutField error
> epics> dbpr LS450PS:asyn 10
> ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 0
> AINP: AOUT: AQR: 0 ASG:
> ASP: (nil) AUCT: autoConnect BAUD: Unknown BINP: 0
> BKPT: 00 BOUT: 0 CNCT: Connect DBIT:
> Unknown
> DESC: DISA: 0 DISP: 0 DISS:
> NO_ALARM
> DISV: 1 DPVT: 0x99daeb0 DRVINFO: DSET:
(nil)
> DTYP: asynRecordDevice ENBL: Enable EOMR: None
> ERRS: 0x99db190 EVNT: 0 F64INP: 0 F64IV: 0
> F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV: 0
> I32INP: 0 I32IV: 0 I32OUT: 0 IEOS:
> IFACE: asynOctet IFMT: ASCII IMAX: 80 IPTR:
> 0x99db0e0
> LCNT: 0 LSET: 0xfacbe0 MCTL: Unknown
> MLIS: 00 00 00 00 00 00 00 00 80 81 9d 09 MLOK: 00
00
> 00 00
> NAME: LS450PS:asyn NAWT: 0 NORD: 0 NOWT: 80
> NRRD: 0 NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 1
> OEOS: OFMT: ASCII OMAX: 80 OPTIONIV:
0
> OPTR: 0x99db088 PACT: 0 PCNCT: Connect PHAS: 0
> PINI: NO PORT: sockserv PPN: (nil) PPNR:
(nil)
> PRIO: LOW PROC: 0 PRTY: Unknown PUTF: 0
> RDES: 0xfacc00 REASON: 0 RPRO: 0 RSET:
(nil)
> SBIT: Unknown SCAN: Passive SDIS:CONSTANT SEVR:
> NO_ALARM
> SOCK: SPR: 0 SPVT: (nil) STAT:
> NO_ALARM
> TB0: On TB1: Off TB2: Off TB3: Off
> TB4: Off TFIL: Unknown TIB0: Off TIB1: Off
> TIB2: Off TIME: c8 ba 9d 09 00 00 00 00 TINP:
> TIOM: 0 TMOD: Write/Read TMOT: 1 TMSK: 1
> TPRO: 0 TSE: 0 TSEL:CONSTANT TSIZ: 80
> UCMD: None UDF: 0 UI32INP: 0 UI32IV: 0
> UI32MASK: 4294967295 UI32OUT: 0 VAL:
> epics> asynReport 10 sockserv
> sockserv multiDevice:No canBlock:Yes autoConnect:Yes
> enabled:Yes connected:Yes numberConnects 1
> nDevices 0 nQueued 0 blocked:No
> asynManagerLock:No synchronousLock:No
> exceptionActive:No exceptionUsers 2 exceptionNotifys 0
> interposeInterfaceList
> asynOctet pinterface 0xfac6a0 drvPvt 0x99d23a8
> interfaceList
> asynCommon pinterface 0xfab7d4 drvPvt 0x99d1ce0
> asynOctet pinterface 0x99d1d28 drvPvt 0x99d1ce0
> Port 127.0.0.1:9099: Connected
> fd: 6
> Characters written: 0
> Characters read: 0
> Thanks,
> William
> Mark Rivers wrote:
>> Something is wrong, that should work fine. Here's what I get on a
> record connected to a VXI11 driver:
>> epics> dbpf asynRecord.AOUT "test"
>> DBR_STRING: "test"
>> epics> dbpr asynRecord 10
>> ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 3
>> AINP: +1.0071E+21
>> AOUT: test AQR: 0 ASG:
> Unknown
> NO_ALARM
>> DISV: 1 DPVT: 0x8acb750 DRVINFO: DSET:
> 0x163908
>> DTYP: asynRecordDevice ENBL: Enable EOMR: End
>> ERRS: 0x8acba58 EVNT: 0 F64INP: 0 F64IV: 0
>> F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV: 1
>> I32INP: 0 I32IV: 1 I32OUT: 0 IEOS:
>> IFACE: asynOctet IFMT: ASCII IMAX: 200 IPTR:
> 0x8acb958
>> LCNT: 0 LSET: 0x8aced90 MCTL: Unknown
>> MLIS: 88 fb b0 08 d8 f6 b0 08 1f 00 00 00 MLOK: 38
> b7 ac 08
>> NAME: asynRecord NAWT: 4 NORD: 13 NOWT: 80
1
>> OEOS: OFMT: ASCII OMAX: 40 OPTIONIV:
> 1
>> OPTR: 0x8acb928 PACT: 0 PCNCT: Connect PHAS: 0
>> PINI: NO PORT: L0 PPN: (nil) PPNR:
> (nil)
>> RDES: 0x8aa8db0 REASON: 0 RPRO: 0 RSET:
> 0x1638c0
> NO_ALARM
> NO_ALARM
>> TIB2: Off TIME: 2010-06-16 08:48:57.406695215
>> TINP: +1.0071E+21\r\n TIOM: 0 TMOD:
> Write/Read
>> TMOT: 1 TMSK: 1 TPRO: 0 TSE: 0
>> TSEL:CONSTANT TSIZ: 80 UCMD: None UDF: 0
>> UI32INP: 0 UI32IV: 0 UI32MASK: 4294967295
>> UI32OUT: 0 VAL:
>> Please send the complete output of the following 2 commands:
>> ________________________________
>> From: [email protected] on behalf of William Lu
>> Sent: Tue 6/15/2010 4:46 PM
>> To: Ralph Lange
>> Cc: [email protected]
> Fields
>> The dbpf does not work. It gives the error message as below:
>> epics> dbpf LS450PS:asyn.AOUT abc
>> Thanks,
>> William Lu
>> Ralph Lange wrote:
>>> Can you change the fields locally from the ioc shell (using "dbpf")?
>>> If yes, is Access Security enabled? Do you have write access rights?
>>> ("cainfo" on the client machine will tell you.)
>>> Ralph
>>> On Tue 15 Jun 2010 15:39:33 William Lu wrote:
>>>> I am having problems with channel access writes on asyn record's
>>>> writable fields such AOUT and PORT. I created the following asyn
>>>> tcp/ip port and the asyn record:
>>>> In a startup iocsh script:
>>>> drvAsynIPPortConfigure("sockserv","127.0.0.1:9099",0,0,0)
>>>> The asyn record:
>>>> record(asyn, LS450PS:asyn) {
>>>> field(DTYP, "asynRecordDevice")
>>>> field(PORT, "sockserv")
>>>> field(ADDR,"0")
>>>> After the record has been loaded to the ioc, I cannot write the
AOUT
>>>> or PORT fields of the record through channel access. When I caput
> on
>>>> those fields, I got the error messages like the following:
>>>>> caput LS450PS:asyn.AOUT "abc"
>>>> Old : LS450PS:asyn.AOUT
>>>> CA.Client.Diagnostic..............................................
>>>> Message: "Could not perform a database value put for that
> channel"
>>>> Severity: "Warning" Context: "detected by:
>>>> devl17.acc.jlab.org:5064 for: LS450PS:asyn - with request
>>>> chan=LS450PS:asyn.AOUT op=1 data type=DBR_STRING count=1"
>>>> New : LS450PS:asyn.AOUT
>>>> What is the problem? Any help would be gratefully appreciated.
>>>> William Lu
>>>> Jefferson Lab
>> Weiwei Lu
>> 757-269-7476
>> [email protected]
Weiwei Lu
757-269-7476
[email protected]
- Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
- Channel Access Writes Failed on Asyn Record Writable Fields William Lu
- Re: Channel Access Writes Failed on Asyn Record Writable Fields Ralph Lange
- RE: Channel Access Writes Failed on Asyn Record Writable Fields Mark Rivers
<2010>
2025
2026
<2010>
2025
2026
