1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: linking to shared objects user libraries
Cc: [email protected]
Date: Fri, 09 Jul 2010 11:12:24 -0500
As requested:
~/iocTops/TargetMon/configure/CONFIG_SITE:
      1 # CONFIG_SITE
      2
      3 # Make any application-specific changes to the EPICS build
      4 # configuration variables in this file.
      5 #
      6 # Host/target specific settings can be specified in files named
      7 #  CONFIG_SITE.$(EPICS_HOST_ARCH).Common
      8 #  CONFIG_SITE.Common.$(T_A)
      9 #  CONFIG_SITE.$(EPICS_HOST_ARCH).$(T_A)
     10
     11 # Set this when you only want to compile this application
     12 # for a subset of the cross-compiled target architectures
     13 # that Base is built for.
     14 #CROSS_COMPILER_TARGET_ARCHS = vxWorks-68040
     15
     16 # Set this when your IOC and the host use different paths
     17 # to access the application. This will be needed to boot
     18 # from a Microsoft FTP server or with some NFS mounts.
     19 # You must rebuild in the iocBoot directory for this to
     20 # take effect.
     21 #IOCS_APPL_TOP = <path to application top as seen by IOC>
     22
     23 # If you don't want to install into $(TOP) then
     24 # define INSTALL_LOCATION here
     25 #INSTALL_LOCATION=<fullpathname>
     26
     27 STATIC_BUILD=NO
     28 SHARED_LIBRARIES=YES
Here's the makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
PROD_IOC = TargetMon
# TargetMon.dbd will be created and installed
DBD += TargetMon.dbd
# TargetMon.dbd will be made up from these files:
TargetMon_DBD += base.dbd
TargetMon_DBD += genSub.dbd
TargetMon_DBD += genSubRecord.dbd
TargetMon_DBD += dbGenSubExtra.dbd
# TargetMon_registerRecordDeviceDriver.cpp derives from TargetMon.dbd
TargetMon_SRCS += TargetMon_registerRecordDeviceDriver.cpp
TargetMon_SRCS += readTgtData.c
# Build the main IOC entry point on workstation OSs.
TargetMon_SRCS_DEFAULT += TargetMonMain.cpp
#TargetMon_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#TargetMon_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
USR_INCLUDES += -I/home/epics/Software/MICESoftware/MICETrackerSoftware/BeamLossMonitorUtils/include
# Link in the code from the support library
TargetMon_LIBS += /home/epics/Software/MICESoftware/MICETrackerSoftware/.lib/libMICECoreUtils
TargetMon_LIBS += /home/epics/Software/MICESoftware/MICETrackerSoftware/.lib/libMICEThreads
TargetMon_LIBS += /home/epics/Software/MICESoftware/MICETrackerSoftware/.lib/libMICELogging
TargetMon_LIBS += /home/epics/Software/MICESoftware/MICETrackerSoftware/.lib/libBeamLossHardwareUtils
TargetMon_LIBS += /home/epics/Software/ExtDeps/gzstream/gzstream
z_DIR = /usr/lib
USR_LIBS += z
# Finally link to the EPICS Base libraries
TargetMon_LIBS += $(EPICS_BASE_IOC_LIBS)
TargetMon_LIBS += genSub
TargetMon_LIBS += receive
TargetMon_LIBS += transmit
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
Here's the end of the compilation results:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g  -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/epics/epics/base/include/os/Linux -I/home/epics/epics/base/include  -I/home/epics/epics/Support/include    -I/home/epics/epics/Support/genSub/include     -I/home/epics/Software/MICESoftware/MICETrackerSoftware/BeamLossMonitorUtils/include    ../TargetMonMain.cpp
make[3]: *** No rule to make target `../../../lib/linux-x86/lib/home/epics/Software/MICESoftware/MICETrackerSoftware/.lib/libMICECoreUtils.a', needed by `TargetMon'.  Stop.
make[3]: Leaving directory `/home/epics/epics/iocTops/TargetMon/TargetMonApp/src/O.linux-x86'make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/epics/epics/iocTops/TargetMon/TargetMonApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/epics/epics/iocTops/TargetMon/TargetMonApp'
make: *** [TargetMonApp.install] Error 2
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Friday, July 9, 2010 10:03 am
Subject: RE: linking to shared objects user libraries
To: Pierrick Hanlet <[email protected]>, "J. Lewis Muir" <[email protected]>
> Can you send the Makefile and the exact error message when you build?
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Pierrick Hanlet
> Sent: Friday, July 09, 2010 9:59 AM
> To: J. Lewis Muir
> Subject: Re: linking to shared objects user libraries
> Thanks for the quick responses.
> Yes, I did STATIC_BUILD=NO and SHARED_LIBRARIES=YES
> in xxx/configure/CONFIG_SITE.
> Where might these be overwritten?  Also, since I'm using a
> mixture of static and shared object libraries, will this
> configuration fix me to one type of library or another?
> Pierrick
> Pierrick Hanlet
> Batavia, IL 60510
> [email protected]
> From: "J. Lewis Muir" <[email protected]>
> Date: Friday, July 9, 2010 9:50 am
> To: [email protected]
> > On 7/9/10 9:38 AM, Pierrick Hanlet wrote:
> > > Hi,
> > > I'm using 3.14.11 on a linux machine. I would like to use several
> > > external (i.e. non-EPICS) .so libraries in my ioc makefile/ However,
> > > the linking appears to default to static libraries. According to the
> > > applications developers guide, section 4.6.23.7, I should modify
> > > CONFIG_SITE, but this doesn't work.
> > > What should I do?
> > Hi, Pierrick.
> > Did you try setting both STATIC_BUILD=NO and SHARED_LIBRARIES=YES?
> > Also, check to make sure your IOC's configuration isn't changing those
> > variables.  If it is, you will need to remove or change them their
> too.
> > Lewis
RE: RE: linking to shared objects user libraries Mark Rivers
RE: RE: linking to shared objects user libraries Davidsaver, Michael
linking to shared objects user libraries Pierrick Hanlet
Re: linking to shared objects user libraries J. Lewis Muir
Re: linking to shared objects user libraries Pierrick Hanlet
Prev: Re: VxWorks 6.7, MV5500 Andrew Johnson
Next: RE: RE: linking to shared objects user libraries Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: linking to shared objects user libraries Mark Rivers
