Hi, Attached are EDM equivalents of the MEDM screens for asyn record. They are a result of adl2edl conversion. Zen > -----Original Message----- > From: [email protected] [mailto:[email protected]] > On Behalf Of Rod Nussbaumer > Sent: Thursday, February 17, 2011 2:27 PM > To: Mark Rivers > Cc: EPICS tech-talk > Subject: Re: stream without asynPort > > Mark Rivers wrote: > >> When these are set to produce verbose console output, it can be > > difficult to turn them off by > >> typing. Hooking them to EPICS records like multibit binaries could > > make it really > >> convenient. > > > > That's already possible. You just connect an asyn record to that asyn > > port. The asyn record has a nice medm screen which lets you turn the > > mask bits on and off. Moreover, a single asyn record can be switched > > between ports (and between asyn "addr" addresses) so you don't > > necessarily need one asyn record for each port, a single asyn record per > > IOC would be sufficient. > > > > Mark > > Okay, I will have to try that, in the case of setting asynTrace masks. > However, in the more general case, I think being able to use > streamDevice's exec functions would still benefit from being able to > access the attached PV. > > Has anyone done a conversion of the MEDM screens to EDM screens related > to the asyn record? I've often wanted to play with the asyn record, but > it always looked like the secret to its use was somewhat embedded in the > screens, and we only use EDM here. I guess I'll have to see if there is > a Capfast symbol for the asyn record, too... > > Thanks. > > --- rod. Attachment:
asynGPIBSetup.edl Attachment:
asynOctet.edl Attachment:
asynRecord.edl Attachment:
asynRegister.edl Attachment:
asynSerialPortSetup.edl Attachment:
asynSocketSetup.edl Attachment:
ipSNCServer.edl
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
