1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Binding an IOC to a single network interface
Cc: [email protected]
Date: Mon, 06 Oct 2014 17:03:40 -0500
On 10/6/14 4:24 PM, Andrew Johnson wrote:> Hi Lewis,
> http://bazaar.launchpad.net/~epics-core/epics-base/3.15/revision/12508
> This was a reimplementation of Freddie's patch, making use of the
> address-list parsing code that was already in Base. If the env var
> contains more than one interface IP it will only use the first one and
> print a warning message (as Freddie's code did).
Hi, Andrew.
OK.  I had just searched the code for "EPICS_CAS_INTF_ADDR_LIST" and
didn't find it, so I concluded you hadn't added it yet.  I guess the
reason it's not there is because you used the address-list parsing code.
> The CA repeater is part of the CA client library, it is not related to
> either CA server at all.
OK, that's why I suggested a different environment variable would be
needed if it wasn't considered part of the CA server.
> There can only be one CA repeater running on any system, and since all
> clients running on the system need to connect to that single instance
> irrespective of which interfaces they will be searching through, it
> does not need the same kind of configuration variable.
For my use case, I still wish for it.  I have a development machine, and
I want everything to be listening on the loopback interface--nothing
else.  I wish for an easy way to do that.  caRepeater listens on all
interfaces; I just want it to bind to the loopback interface; that's it.
If a new environment variable such as EPICS_CA_REPEATER_INTF_ADDR_LIST
were used, would you be open to that?  Or, if you don't like using an
environment variable, what about a command line option to caRepeater to
allow me to specify the bind address (assuming I always start caRepeater
before something that starts it automatically for me)?
Lewis
Re: Binding an IOC to a single network interface J. Lewis Muir
Re: Binding an IOC to a single network interface Andrew Johnson
Binding an IOC to a single network interface freddie.akeroyd
Prev: Re: [EPICS] Support for Staged Installs ? J. Lewis Muir
Next: TCP connection status : drvAsynIPPort Patel Jignesh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Binding an IOC to a single network interface Andrew Johnson
Next: Re: Binding an IOC to a single network interface J. Lewis Muir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
