On 10/6/14 5:03 PM, J. Lewis Muir wrote:
> If a new environment variable such as EPICS_CA_REPEATER_INTF_ADDR_LIST
> were used, would you be open to that?
Below is an updated patch that now uses a new environment
variable: EPICS_CA_REPEATER_INTF_ADDR_LIST. On my machine, setting
that variable to 127.0.0.1 makes caRepeater bind to that address on my
loopback interface as desired.
Lewis
--- src/ca/repeater.cpp.orig 2013-12-16 15:56:27.000000000 -0600
+++ src/ca/repeater.cpp 2014-10-03 17:12:12.000000000 -0500
@@ -115,6 +115,7 @@
struct sockaddr_in ia;
struct sockaddr sa;
} bd;
+ const char* pStr;
SOCKET sock = epicsSocketCreate ( AF_INET, SOCK_DGRAM, 0 );
if ( sock == INVALID_SOCKET ) {
@@ -128,8 +129,19 @@
memset ( (char *) &bd, 0, sizeof (bd) );
bd.ia.sin_family = AF_INET;
- bd.ia.sin_addr.s_addr = htonl ( INADDR_ANY );
- bd.ia.sin_port = htons ( port );
+ pStr = envGetConfigParamPtr ( & EPICS_CA_REPEATER_INTF_ADDR_LIST );
+ if (pStr) {
+ /* this implementation only allows for specifying a single address in EPICS_CA_REPEATER_INTF_ADDR_LIST */
+ status = aToIPAddr ( pStr, port, &bd.ia );
+ if (status) {
+ fprintf( stderr, "CA Repeater: error parsing %s '%s'\n", EPICS_CA_REPEATER_INTF_ADDR_LIST.name, pStr );
+ bd.ia.sin_addr.s_addr = htonl ( INADDR_ANY );
+ bd.ia.sin_port = htons ( port );
+ } else {
status = bind ( sock, &bd.sa, (int) sizeof(bd) );
if ( status < 0 ) {
epicsSocketDestroy ( sock );
--- src/libCom/env/envDefs.h.orig 2013-12-16 15:56:27.000000000 -0600
+++ src/libCom/env/envDefs.h 2014-10-07 09:52:14.000000000 -0500
@@ -45,6 +45,7 @@
epicsShareExtern const ENV_PARAM EPICS_CA_ADDR_LIST;
epicsShareExtern const ENV_PARAM EPICS_CA_CONN_TMO;
epicsShareExtern const ENV_PARAM EPICS_CA_AUTO_ADDR_LIST;
+epicsShareExtern const ENV_PARAM EPICS_CA_REPEATER_INTF_ADDR_LIST;
epicsShareExtern const ENV_PARAM EPICS_CA_REPEATER_PORT;
epicsShareExtern const ENV_PARAM EPICS_CA_SERVER_PORT;
epicsShareExtern const ENV_PARAM EPICS_CA_MAX_ARRAY_BYTES;
- Re: Binding an IOC to a single network interface J. Lewis Muir
- Binding an IOC to a single network interface freddie.akeroyd
- Re: Binding an IOC to a single network interface Andrew Johnson
RE: waveform record with Nexus Mark Rivers
RE: waveform record with Nexus Juliano Ferreira Jorge Murari
<2014>
2025
2026
<2014>
2025
2026
