1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn: what if a driver wants to force callbacks?
Cc: "[email protected]" <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Fri, 27 May 2016 10:29:31 -0300
 Mark, I think this behavior is incorrect, because it does not respect
the value of MDEL and MPST.
2016-05-27 10:10 GMT-03:00 Mark Rivers <[email protected]>:
> It is all really the same thing, which is the behavior of asynPortDriver. It only does callbacks to device support when a value changes.  This is the desired behavior most of the time. You can currently easily work around that by setting 2 different values before calling callParamCallbacks. I will add a forceCallbacks() method for the next release of asyn.
> You need to keep in mind that even if the driver does the callback to device support, the record may not post a new monitor on the value, depending on the record type and the value of the MDEL field.
> Mark
> Sent from my iPhone
>> On May 27, 2016, at 2:42 AM, Torsten Bögershausen <[email protected]> wrote:
>> To my understanding,
>> we are talking about 3 different things:
>> a) an asyn record
>> b) a motor Record
>> c) Area Detector
>> I can only talk about b), and there is no update,
>> you still need a workaround in the driver, at least for now.
>> How the area detector is related to the motor update, I don't know.
>> HTH
>>> On 27/05/16 04:49, Henrique Almeida wrote:
>>> I don't think so, I had this problem on Wednesday while writing an areaDetector
>>> IOC that updates a waveform record whenever a new image is saved. If the same
>>> file name is used twice in a row, the second callback does not emit a monitor
>>> event. I'm using EPICS base 3.16 and asyn and areaDetector github master branch.
>>> Em 26/05/2016 10:08, "Mark Davis" <[email protected] <mailto:[email protected]>>
>>> escreveu:
>>>    On 5/26/2016 1:52 AM, Torsten Bögershausen wrote:
>>>    I remember that Mark Rivers had said something about changing it so that a
>>>    callback would happen for parameters for which the appropriate
>>>    setXxxParam() function was called, even if the value had not changed.  And
>>>    I THINK that it made it in to one of the more recent versions, but if so, I
>>>    don't remember which one.
>>>    Mark Davis, FRIB/NSCL
>>>>    To my knowledge,
>>>>    there is no update.
>>>>    In our driver, we do it like this:
>>>>        /* If not moving, trigger a record processing at low rate */
>>>>        if (!nowMoving) setDoubleParam(pC_->motorPosition_,
>>>>    newPositionInSteps + 1);
>>>>        setDoubleParam(pC_->motorPosition_, newPositionInSteps);
>>>>    And I added a test case:
>>>>    https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
>>>>    Out of curiosity:
>>>>    Which kind of device are you using ?
>>>>>    On 25/05/16 23:50, Ford, Christopher wrote:
>>>>>    Hi,
>>>>>    In 2015 there was some discussion on Tech-Talk about how to force a
>>>>>    callback for a parameter that had not changed values.
>>>>>    Mark Rivers suggested a work-around, as shown below.
>>>>>    I wonder if anyone has an update on the situation since then?  Has any
>>>>>    other method appeared?  Or did you have success with the work-around?
>>>>>    Thanks,
>>>>>     -Chris Ford, SLAC
>>>>>    On16 Nov 2015 Mark Rivers writes:
>>>>>>    If a driver wants to force a callback there is a method that does not
>>>>>>    require any changes to the base classes, e.g. exposing statusChanged_
>>>>>>    as protected or adding a new
>>>>>>    isMotorRecordnowFilterButAlwaysProcess_ flag.  The driver simply needs
>>>>>>    to set a parameter to a different value from present and then back to
>>>>>>    its current value, for example
>>>>>>     setDoubleParam(pC_->motorPosition_(position+1.);
>>>>>>     setDoubleParam(pC_->motorPosition_(position);
>>>>>>     callParamCallbacks();
>>>    Mark Davis
>>>    NSCL/FRIB Control Systems Software Engineer
>> a
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
RE: Area Detector question Mark Rivers
asyn: what if a driver wants to force callbacks? Ford, Christopher
Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
Re: asyn: what if a driver wants to force callbacks? Mark Davis
Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
Re: asyn: what if a driver wants to force callbacks? Mark Rivers
Prev: Re: archiver appliance vs. data browser junkes
Next: RE: archiver appliance vs. data browser michael.kenning
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn: what if a driver wants to force callbacks? Mark Rivers
Next: Re: asyn: what if a driver wants to force callbacks? Ford, Christopher
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
