I understand sir, I did like that. But when I add these path in Octave : (/opt/epics/extensions/lib/linux-x86_64) iand (/opt/epics/extensions/src/mca/matlab) .. And in Octave when i type "help mcaopen" , it says the definition and usage of that command. However, according to the your example,when I use Octave to read PV from the ioc like this (pv=mcaopen('hulusiHost:ai1') , I've got this : %%%%%%% pv=mcaopen('hulusiHost:ai1') error: mcaopen: /opt/epics/extensions/lib/linux-x86_64/mca.mex: failed to load: libCom.so.3.14: cannot open shared object file: No such file or directory error: called from %%%%%%% In the search path of Octave these path are included.I can see them. Thanks in advance.. Best Regards.. Hulusi 2016-07-23 3:14 GMT+03:00 Eric Norum <[email protected]>:
| ANJ, 23 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
