Hi Kevin,
What I meant to suggest was to consider taking the python code you are using to turn PV events into electronic-logbook entries out of the SNL code and run that code in a separate process. You might have to change some logic about when logging events get triggered, but that might be as simple as setting a PV flag to mean "log now", and then have the python process look for changes in that PV and act accordingly. Having a long/infinitely-running python process looking for a PV state change and then doing some combination of CA and logging/database interaction is really very easy. I do this all the time. But, to summarize the earlier suggestions: if you are embedding pyepics in SNL, you might need to create a new CA context in the python script with import epics epics.ca.context_create(0) I don't know for sure that this is needed, but from the problems you describe it seems worth trying. --Matt
- Re: SNL sequencer apparently losing connection to underlying network Pearson, Matthew R.
- Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
- Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
- Re: SNL sequencer apparently losing connection to underlying network Matt Newville
Re: display two opi viewers on different monitors Kasemir, Kay
<2016>
2025
2026
<2016>
2025
2026
ANJ, 06 Dec 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
