1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL sequencer apparently losing connection to underlying network
To: Matt Newville <[email protected]>, Kevin Meyer <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Tue, 6 Dec 2016 17:50:43 +0100
On 02.12.2016 15:30, Matt Newville wrote:
> But, to summarize the earlier suggestions: if you are embedding pyepics in
> SNL,  you might need to create a new CA context in the python script with
>     import epics
>     epics.ca.context_create(0)
Hi Matt
I may be wrong but I think this is what already happens (implicitly).
The problem is that the newly created context replaces (overwrites) the
old one and then (afterwards) channels created against the old context
fail to work.
My suggestion (to repeat) is to use ca_current_context to get the
existing CA client context on startup (so that you don't overwrite the
existing context with a new one) and to somehow convince the Python
binding to NOT call ca_context_destroy when it exits. For this you could
perhaps use ca_detach_context before Python shuts down (to avoid killing
the existing context) but then you would have to save and restore the
context inside the SNL code. However, perhaps the shutdown is not really
a problem because the Python runtime system is kept alive all the time?
(I.e. as long as the SNL is running) In that case, simply ignore shutdown.
It is important to understand that the CA client library CANNOT have two
CA client contexts active inside the same user thread. If you try that,
strange things start to happen. The reason for this is that the client
context is stored in a fixed location in thread local memory. What you
can do is pull out an existing context, create a new one, work with it,
destroy it, and then restore the old context afterwards (using
ca_attach_context or some such).
You CAN open two channels to the same PV (inside the same client
context) without problems.
Apart from that, I completely agree with your (Matt's) suggestion to do
everything on the Python side. In this (Kevin's) case this would indeed
mean to generate Python code, which I guess isn't that much harder than
generating SNL...
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: SNL sequencer apparently losing connection to underlying network Matt Newville
Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
Re: SNL sequencer apparently losing connection to underlying network Benjamin Franksen
Prev: Re: Simultaneous Channel access Marty Kraimer
Next: RE: Simultaneous Channel access matthew.taylor
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNL sequencer apparently losing connection to underlying network Pearson, Matthew R.
Next: Re: SNL sequencer apparently losing connection to underlying network Matt Newville
ANJ, 06 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
