Hi there,
the trick worked to use dlopen() instead of .so dependencies. THANK YOU!
But as in Linux 32-bit you have to delay the unload of the stub library
(in my case 5 seconds).
I think it can work as workaround but is not the real fix for the issue.
If you check libca.so and libCom.so at Linux 64-bit you will see
following log:
standard@standard-VirtualBox:~$ valgrind --leak-check=full
--show-leak-kinds=all
/usr/local/epics/base-3.14.12.6/lib/linux-x86_64/libca.so
==4880== Memcheck, a memory error detector
==4880== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==4880== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==4880== Command: /usr/local/epics/base-3.14.12.6/lib/linux-x86_64/libca.so
==4880==
==4880== Jump to the invalid address stated on the next line
==4880== at 0x23166: ???
==4880== by 0x12C9AF: assertIdenticalMutex (epicsGuard.h:81)
==4880== by 0x12C9AF: cac::flush(epicsGuard<epicsMutex>&) [clone
.part.63] (cac.cpp:1208)
==4880== Address 0x23166 is not stack'd, malloc'd or (recently) free'd
==4880==
==4880==
==4880== Process terminating with default action of signal 11 (SIGSEGV)
==4880== Bad permissions for mapped region at address 0x23166
==4880==
==4880== HEAP SUMMARY:
==4880== in use at exit: 0 bytes in 0 blocks
==4880== total heap usage: 0 allocs, 0 frees, 0 bytes allocated
==4880==
==4880== All heap blocks were freed -- no leaks are possible
==4880==
==4880== For counts of detected and suppressed errors, rerun with: -v
==4880== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
/usr/local/epics/base-3.14.12.6/lib/linux-x86_64/libCom.so
==4885== Memcheck, a memory error detector
==4885== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==4885== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==4885== Command: /usr/local/epics/base-3.14.12.6/lib/linux-x86_64/libCom.so
==4885==
==4885== Jump to the invalid address stated on the next line
==4885== at 0x1D556: ???
==4885== by 0x12706A: epicsMutex::lock() [clone .part.2]
(epicsMutex.cpp:249)
==4885== Address 0x1d556 is not stack'd, malloc'd or (recently) free'd
==4885==
==4885==
==4885== Process terminating with default action of signal 11 (SIGSEGV)
==4885== Bad permissions for mapped region at address 0x1D556
==4885==
==4885== HEAP SUMMARY:
==4885== in use at exit: 0 bytes in 0 blocks
==4885== total heap usage: 0 allocs, 0 frees, 0 bytes allocated
==4885==
==4885== All heap blocks were freed -- no leaks are possible
==4885==
==4885== For counts of detected and suppressed errors, rerun with: -v
==4885== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
Best reagards
Carsten
Am 24.02.2017 um 21:33 schrieb Michael Davidsaver:
> On 02/24/2017 12:46 PM, Carsten Winkler (HZB) wrote:
>> Hi Michael,
>> thanks for your help.
>> I wrote a stub library first, before I got the memory issues. It worked
>> very well (since 2010) in Windows at 32-bit and 64-bit. In Linux 32-bit
>> I could avoid the problem with delayed unloading the stub lib. Now I
>> want to support Linux 64-bit too. But the delay trick doesn't work in
>> that environment. That's the full story. You see, I have an old project
>> that's running into problems under special conditions.
>> Do you have any other advice for me?
> Other the totally unhelpful suggestion not to use labview ;) you could
> have your stub library use dlopen() instead of .so dependencies.
>> Best regards
>> Carsten
>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
>> Forschungszentren e.V.
>> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende
>> Dr. Jutta Koch-Unterseher
>> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>> Postadresse:
>> Hahn-Meitner-Platz 1
>> D-14109 Berlin
>> http://www.helmholtz-berlin.de
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Postadresse:
D-14109 Berlin
- memory leak after unloading of ca.lib Carsten Winkler
- Re: memory leak after unloading of ca.lib Michael Davidsaver
- Re: memory leak after unloading of ca.lib Ben Franksen
- RE: memory leak after unloading of ca.lib Hill, Jeff
- Re: memory leak after unloading of ca.lib Carsten Winkler
- Re: memory leak after unloading of ca.lib Carsten Winkler (HZB)
PCASpy 0.6.3 Wang Xiaoqiang (PSI)
RE: RE: RE: Re: IOC Connecting Problem Pilkyu Jung
<2017>
2025
2026
<2017>
2025
2026
