1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget randomly returns Channel connect timed out
To: [email protected]
Cc: Talk EPICS Tech <[email protected]>
Date: Mon, 16 Jul 2018 09:39:02 -1000
Hi all,
Thanks for these replies. It is very possible we have newer Cisco switches installed
at various places throughout both our telescopes. I will try to find out the models and
see if we can capture packets on this one troublesome instrument (EPICS  3.14.8.2).
This thread has evolved. So I want to be clear that there may be two similar issues here:
1) In the original post I reported a problem how a script on linux calling caget once per
second can timeout talking to our new Telescope Control System (TCS) IOC running
RTEMS-4.10.2/EPICS-3.14.12.7. We couldn't find such timeouts on the legacy
TCS running VxWorks 5.4/ EPICS-3.13.9.   When these timeouts occur, we _DO NOT_
see any log messages on our TCS. I'll try to use Michael's cashark plugin to learn more.
2) Then, my colleague Ignacio at Gemini South posted a similar case where one of
our instruments (3.14.8.2) calls caget and often fails with the new TCS. Every time this caget
fails we see this:
Jul 12 12:40:59  E) PORT: tcs_vme, MSG: CAS: request from 172.17.102.130:57113 => bad resource ID
Jul 12 12:40:59  E) PORT: tcs_vme, MSG: CAS: Request from 172.17.102.130:57113 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0
Jul 12 12:40:59  E) PORT: tcs_vme, MSG: CAS: Request from 172.17.102.130:57113 =>   available=0x1       N=0 paddr=0x0
Jul 12 12:40:59  E) PORT: tcs_vme, MSG: CAS: forcing disconnect from 172.17.102.130:57113
There's a Holiday in Chile today but I hope they can arrange to capture some packets
in the next day or two. Details are forthcoming.
Thank you again,
-Matt
On Mon, Jul 16, 2018 at 8:59 AM Andrew Johnson <[email protected]> wrote:
Hi Mark,
On 07/16/2018 12:18 PM, Mark Rivers wrote:
> I thought we were doing directed UDP broadcasts to Cisco switches at
> the APS.
> Isn't that doing a directed UDP broadcast to the switch for the
> 164.54.162.* subnet?
If my internal investigations are correct you have an HP ProCurve switch
connecting your two subnets, which is why this still works for you.
Apparently it *is* possible to configure Cisco switches to allow this,
according to the last answer to this StackOverflow question:
https://stackoverflow.com/questions/379015/udp-broadcast-packets-across-subnets
This article from Cisco seems to explain how:
  http://www.ciscopress.com/articles/article.asp?p=330807&seqNum=9
If you have a system available with a network interface on both subnets
you could also run a pair of UDP Broadcast Packet Relays to pass
broadcasts between them, on both ports 5064 and 5065. More information
on this is available at
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access#UDP_Broadcast_Packet_Relay
- Andrew
caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Andrew Johnson
Re: caget randomly returns Channel connect timed out Michael Davidsaver
Re: caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Dirk Zimoch via Tech-talk
RE: caget randomly returns Channel connect timed out Mark Rivers
Prev: Re: caget randomly returns Channel connect timed out Andrew Johnson
Next: Question about store array in MySQL by using RDB Channel Archive lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: caget randomly returns Channel connect timed out Dirk Zimoch
ANJ, 17 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
