1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>, Ralph Lange <[email protected]>
Date: Tue, 21 Jan 2020 14:32:44 +0100
Am Tue, 21 Jan 2020 09:45:10 +0100
schrieb Ralph Lange via Tech-talk <[email protected]>:
> > No error messages to be seen during the build,
> > though. What do I have to check to find out where this is not being
> > picked up properly?
> You will have to set CALC to an absolute path pointing to your
> installation of the calc module in your application's configure/RELEASE
> file (don't use the environment), and as well add the dbd snippet that
> calc generates ( calcSupport.dbd, including the definition for the
> scalcout record type) as the name of the library that calc generates
> (calc, containing the code for the scalcout record type) to the
> appropriate definitions in your application's Makefile (where the IOC
> binary is created).
Thanks for the detailed explanation! Turns out I was simply missing the
inclusion of the calc.dbd file. Having added that, everything is happily
compiling now. The created dbd file looks ok, and libcalc is linked
against the binary as it should.
BTW: Is there some place where implemented protocols for StreamDevice are
being collected? I guess there must be solutions for many different
devices already existing out there...
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
