Subject: Re: XSPRESS3 hdf5 problems
From: John Dobbins via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 27 Jan 2020 17:27:54 +0000
Mark,
Thanks,  adding STATIC_BUILD=YES to xspress3/iocs/xspress3IOC/xspress3App/src/Makefile works.
John
Sent: Monday, January 27, 2020 12:18 PM
To: John Dobbins <[email protected]>; [email protected] <[email protected]>
Cc: Matt Newville <[email protected]>
Subject: RE: XSPRESS3 hdf5 problems
Hi John,
This is what I get when I build with gcc 4.8.5 on a Centos 7 system with base 7.0.3.1.  It works when I build statically (STATIC_BUILD=YES).
/usr/bin/g++ -o xspress3App -Wl,-Bstatic -L/home/epics/devel/xspress3-2-2/lib/linux-x86_64 -L/home/epics/devel/xspress3-2-2/iocs/xspress3IOC/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-8/ADCore/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-8/ADSupport/lib/linux-x86_64 -L/home/epics/devel/asyn-4-37/lib/linux-x86_64 -L/home/epics/devel/autosave-5-10/lib/linux-x86_64 -L/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -L/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -L/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -L/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -L/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -L/usr/local/epics-devel/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/xspress3-2-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/xspress3-2-2/iocs/xspress3IOC/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-8/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-8/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/asyn-4-37/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/autosave-5-10/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics-devel/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         xspress3App_registerRecordDeviceDriver.o xspress3AppMain.o    -lxspress3Epics -lxspress3 -limg_mod -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lboost_system -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl –lgcc
If I edit xspress3/iocs/xspress3IOC/xspress3App/src/Makefile to have STATIC_BUILD=NO it fails the same as you:
/usr/bin/g++ -o xspress3App  -L/home/epics/devel/xspress3-2-2/lib/linux-x86_64 -L/home/epics/devel/xspress3-2-2/iocs/xspress3IOC/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-8/ADCore/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-8/ADSupport/lib/linux-x86_64 -L/home/epics/devel/asyn-4-37/lib/linux-x86_64 -L/home/epics/devel/autosave-5-10/lib/linux-x86_64 -L/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -L/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -L/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -L/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -L/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -L/usr/local/epics-devel/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/xspress3-2-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/xspress3-2-2/iocs/xspress3IOC/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-8/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-8/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/asyn-4-37/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/autosave-5-10/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics-devel/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         xspress3App_registerRecordDeviceDriver.o xspress3AppMain.o    -lxspress3Epics -lxspress3 -limg_mod -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom  -lboost_system -lX11 -lXext
/bin/ld: /home/epics/devel/xspress3-2-2/lib/linux-x86_64/libxspress3.a(xspress3_histogram.o): undefined reference to symbol 'pthread_cancel@@GLIBC_2.2.5'
//lib64/libpthread.so.0: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [xspress3App] Error 1
make[1]: Leaving directory `/home/epics/devel/xspress3-2-2/iocs/xspress3IOC/xspress3App/src/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
We have not noticed the problem because we normally build statically.  I will investigate.
Meanwhile, you can probably work around the problem by adding STATIC_BUILD=YES to xspress3/iocs/xspress3IOC/xspress3App/src/Makefile.
Sent: Monday, January 27, 2020 10:45 AM
To: [email protected]
Cc: Mark Rivers <[email protected]>; Matt Newville <[email protected]>
Mark, Matt,
I am attempting to build epics-modules/xspress3 (latest master).
On CentOS Linux release 7.5.1804, I have built base 3.15.7, areaDetector R3-7.
If BUILD_IOCS = NO then Xspress3 build succeeds but with BUILD_IOCS=YES I get
/usr/bin/g++ -o xspress3App  -L/home/xspress3/epics/synApps_6_1/support/xspress/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/xspress/iocs/xspress3IOC/lib/linux-x86_64 -L/home/xspress3/epics/base-3.15.7/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/asyn-R4-36/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/iocStats-3-1-16/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/seq-2-2-6/lib/linux-x86_64 -L/home/xspress3/epics/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/xspress/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/xspress/iocs/xspress3IOC/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/base-3.15.7/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/asyn-R4-36/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/autosave-R5-10/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/busy-R1-7-2/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/calc-R3-7-3/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/iocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/seq-2-2-6/lib/linux-x86_64 -Wl,-rpath,/home/xspress3/epics/synApps_6_1/support/sscan-R2-11-3/lib/linux-x86_64           -rdynamic -m64            xspress3App_registerRecordDeviceDriver.o xspress3AppMain.o    -lxspress3Epics -lxspress3 -limg_mod -lNDPlugin -lADBase -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom  -lX11 -lXext
/usr/bin/ld: /home/xspress3/epics/synApps_6_1/support/xspress/lib/linux-x86_64/libxspress3.a(xspress3_histogram.o): undefined reference to symbol 'pthread_cancel@@GLIBC_2.2.5'
//usr/lib64/libpthread.so.0: error adding symbols: DSO missing from command line
On my machine
locate libpthread
/usr/lib64/libpthread-2.17.so
/usr/lib64/libpthread_nonshared.a
readelf -s /lib64/libpthread.so.0 | grep pthread_cancel
   200: 000000000000cae0   167 FUNC    GLOBAL DEFAULT   13 pthread_cancel@@GLIBC_2.2.5
   233: 0000000000000000     0 FILE    LOCAL  DEFAULT  ABS pthread_cancel.c
   485: 00000000000111b4    12 OBJECT  LOCAL  DEFAULT   16 _thread_db_pthread_cancel
   508: 000000000000fe30   260 FUNC    LOCAL  DEFAULT   13 pthread_cancel_init
   949: 000000000000cae0   167 FUNC    GLOBAL DEFAULT   13 pthread_cancel
gcc 4.8.5
Any ideas?
John
Sent: Thursday, January 23, 2020 12:04 PM
Cc: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Hi John,
Just to follow up: I don't recall ever seeing that error from HDF5 with epics-modules/xspress3.  I believe there were some known problems with HDF5 that were fixed around AD 2, but I don't recall the details.
On Thu, Jan 23, 2020 at 10:55 AM John Dobbins <[email protected]> wrote:
Mark,
Thanks. I'll give that a try.
John
Sent: Thursday, January 23, 2020 11:27 AM
Cc: [email protected] <[email protected]>; Matt Newville <[email protected]>
Hi John,
Ø  I have contacted Quantum.  I thought that while waiting to hear from them it would make sense to build an IOC from source. On github I see
Ø  epics-modules/xspress3
The IOC that Quantum distributes is ancient, using areaDetector R1-9-1.
That is the one I recommend you use.  Matt Newville in our group here at the APS is maintaining it.  It is working with the latest version of ADCore, ADSupport, etc.
It uses NDPluginROIStat for ROI statistics.
There are new OPI screens.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, January 23, 2020 8:15 AM
Subject: XSPRESS3 hdf5 problems
All,
I have a new 5 channel Quantum Xspress3 data readout unit which when taking multiple frames will start generating hdf5 related error messages at what seems like random (will acquire between a few or thousands of frames before generating errors).  Once these messages start they seem to continue until the IOC segfaults.
repeating pair of error messages on the IOC console:
 HDF5-DIAG: Error detected in HDF5 (1.8.12) thread 0:
  #000: ../../src/H5Dio.c line 231 in H5Dwrite(): can't prepare for writing data
    major: Dataset
    minor: Write failed
  #001: ../../src/H5Dio.c line 348 in H5D__pre_write(): file selection+offset not within extent
    major: Dataspace
    minor: Out of range
This IOC is a binary that comes with the detector.
and
quantumdetectors/xspress3-epics  forked from the above.
Any advice on which i should go with? Any suspicions regarding the hdf5 errors?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
--Matt Newville
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Prev: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Next: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
