Subject: RE: XSPRESS3 hdf5 problems
To: 'Ralph Lange' <[email protected]>
Date: Mon, 27 Jan 2020 22:02:30 +0000
Hi Ralph,
Thanks for the explanation.
I’d like to add a bit more.
When I build, for example, the simDetector IOC on Centos7 dynamically I do not link with pthread or rt.  It builds fine, and ldd shows that libpthread.so and librt.so are linked and found.  However, the simDetector libraries do not directly call pthread or rt functions, it is only base (or perhaps other libraries) that call pthread or rt.
The difference with the xspress3 IOC is that the xspress3 libraries themselves directly call pthread and rt.  That seems to be the case where they must be included in the PROD_SYS_LIBS.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, January 27, 2020 3:48 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: XSPRESS3 hdf5 problems
Background:
Between RHEL6 and RHEL7, the indirect linking policy changed.
Before, applications could rely on symbols from indirectly linked libraries to be available. E.g., an EPICS IOC could just use pthread calls without explicitly linking against it, knowing that EPICS Base libraries had been linked against pthread and would make the shared library available at run time.
Now, each application must explicitly link against all libraries it uses. (Careful with libraries that use C++ templates in their APIs. They inject source code into your application, so that it may e.g. call pthread without you knowing it. Under the new policy, the pthread library needs to be added in such a case.)
Cheers,
~Ralph
On Mon, 27 Jan 2020 at 19:50, Mark Rivers via Tech-talk <[email protected]> wrote:
Hi John,
I found and fixed the problem.  The pthread and rt libraries needed to be added to PROD_SYS_LIBS.  They appear to be added automatically by the EPICS build system for static builds, but not for dynamic builds.
The master branch should now work correctly for dynamic builds.
XSPRESS3 hdf5 problems John Dobbins via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Re: XSPRESS3 hdf5 problems Ralph Lange via Tech-talk
Prev: Re: XSPRESS3 hdf5 problems Ralph Lange via Tech-talk
Next: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Next: Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
