Subject: Re: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$
From: Pete Jemian via Tech-talk <[email protected]>
To: <[email protected]>
Date: Sat, 7 Aug 2021 17:06:07 -0500
The issue starts when using the base-7.0.6 softIoc.
Using docker image prjemian/epics-base-7.0.5 image, same error happens with 7.0.5
(base) prjemian@zap:~$ docker run -it --rm prjemian/epics-base-7.0.5
root@e14c2b978649:/opt/base-7.0.5# touch /opt/test.db
root@e14c2b978649:/opt/base-7.0.5# nano /opt/test.db
root@e14c2b978649:/opt/base-7.0.5# cat /opt/test.db
record(calc, "test_calc")
    field(SCAN, "1 second")
    field(CALC, "RNDM*100")
root@e14c2b978649:/opt/base-7.0.5# softIoc -d /opt/test.db
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-05-11T02:44+0000
epics> dbl
test_calc
epics>
Now, in separate terminal, apply Kay's command line test:
(base) prjemian@zap:~$ caput -S test_calc.CALC$ "300"
Old : test_calc.CALC$ RNDM*100
New : test_calc.CALC$ 3NDM*100
On 8/7/2021 2:35 PM, Kasemir, Kay via Tech-talk wrote:
Hi:
I subsequently tried out on EPICS base version 7.0.3.1 ..
It works fine ..
I am suspecting the bug may be due to newer version of EPICS.
Looks like you found a problem in R7.0.6.
Take this example record, executed by softIoc:
$ caget -S test_calc.CALC$
CA.Client.Exception...............................................
     Warning: "Channel write request failed"
     Context: "op=1, channel=test_calc.CALC$, type=DBR_CHAR, count=4, ctx="test_calc""
     Source File: ../oldChannelNotify.cpp line 159
     Current Time: Sat Aug 07 2021 15:27:54.755166000
.. and the softIoc shows this error:
Illegal field value PV: test_calc calc: Illegal CALC field
test_calc.CALC: Syntax error, unknown operator/operand in expression "3NDM*100"
So the IOC didn't receive "300" as written, it only took "3" _and_ kept the rest of the previous CALC field value.
When instead using R7.0.4.1, all works fine.
In fact the test also succeeds with softIoc from R7.0.4.1 and caget/caput from base-7.0.6.
-Kay
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Re: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Prev: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Next: Re: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Michael Davidsaver via Tech-talk
