1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: How to: IOC reading information from file?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>
Cc: "Nariyoshi, Pedro" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Nov 2022 12:55:39 -0800
On 11/28/22 12:37, Michael Davidsaver wrote:
On 11/28/22 12:05, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Thanks for the suggestion, Pedro!
At the end of the day, i figured that maybe autosave fdbrestore function would do what i wanted. Unfortunately, the function was resulting in segmentation fault. Looking in tech-talk i found this thread: https://epics.anl.gov/tech-talk/2014/msg01851.php <https://epics.anl.gov/tech-talk/2014/msg01851.php> which suggested that for autosave versions before 5.4.1 it is a known bug which is fixed after that. Since im using autosave 5-10-2 and the PVs are not very long, i gave up using autosave for this.
Could you provide any details which might go into a ticket?
Specific arguments used?  ideally a stack trace?  etc...
https://github.com/epics-modules/autosave/issues
I haven't tried fdbrestore() previously, so I'm not certain about the
caput() errors.  It certainly didn't crash on me.
Did you do full cleanup and rebuild when switching between autosave versions?
(eg. "make distclean", or just deleting and re-downloading the source)
Linking in old object code files is great way to experience some bizarre crashes.
epics> var save_restoreDebug 5
epics> fdbrestore "ioc_settings.sav"
save_restore:fdbrestore:entry
save_restore:request_manual_restore: entry
save_restore task: calling do_manual_restore('ioc_settings.sav')
save_restore:do_manual_restore: entry for file 'ioc_settings.sav'
epics> do_manual_restore:ca_put() to 'TST:Speed-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:DM-Sel.VAL'failed.
do_manual_restore:ca_put() to 'TST:SampT-Sel.VAL'failed.
do_manual_restore:ca_put() to 'TST:SampT:N-Sel.VAL'failed.
do_manual_restore:ca_put() to 'TST:SampDet-Sel.VAL'failed.
do_manual_restore:ca_put() to 'TST:Plt-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Samp-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Plt:N-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Samp:N-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Gn:X-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Gn:Y-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Gn:Z-SP.VAL'failed.
do_manual_restore:ca_put() to 'TST:Tl-Sel.VAL'failed.
save_restore: manual restore status=1 (0==success)
Re: How to: IOC reading information from file? Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Prev: Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Next: RE: Epics Archiver Appliance requests and DST/Timezones Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: How to: IOC reading information from file? Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
