1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: How to: IOC reading information from file?
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, Michael Davidsaver <[email protected]>
Cc: "Nariyoshi, Pedro" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 Nov 2022 14:05:51 +0000
An alternative approach if going down the Python route is to write the whole IOC in Python using pythonSoftIOC. Something like this:
import json
# Import the basic framework components.
from softioc import asyncio_dispatcher, builder, softioc
# Set the record prefix
builder.SetDeviceName("MY-DEVICE-PREFIX")
# Make some dummy data
with open("/tmp/mydata.json", "w") as f:
    f.write('{"my_var": 1.0}')
# Create some records
value = builder.aIn("VALUE", initial_value=0.0)
def set_value_from_json(path: str):
    with open(path) as f:
        text = f.read()
    value.set(json.loads(text)["my_var"])
path = builder.stringOut("PATH", always_update=True, on_update=set_value_from_json)
# Boilerplate get the IOC started
builder.LoadDatabase()
softioc.iocInit(asyncio_dispatcher.AsyncioDispatcher())
# Finally leave the IOC running with an interactive shell.
softioc.interactive_ioc(globals())
# On commandline:
# $ caget MY-DEVICE-PREFIX:VALUE
# MY-DEVICE-PREFIX:VALUE 0.0
# $ caput MY-DEVICE-PREFIX:PATH /tmp/mydata.json
# MY-DEVICE-PREFIX:VALUE 1.0
Tom
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: 28 November 2022 20:55
To: Marco A. Barra Montevechi Filho <[email protected]>
Cc: Nariyoshi, Pedro <[email protected]>; [email protected] <[email protected]>
On 11/28/22 12:37, Michael Davidsaver wrote:
> On 11/28/22 12:05, Marco A. Barra Montevechi Filho via Tech-talk wrote:
>> Thanks for the suggestion, Pedro!
>> At the end of the day, i figured that maybe autosave fdbrestore function would do what i wanted. Unfortunately, the function was resulting in segmentation fault. Looking in tech-talk i found this thread: https://epics.anl.gov/tech-talk/2014/msg01851.php <https://epics.anl.gov/tech-talk/2014/msg01851.php> which suggested that for autosave versions before 5.4.1 it is a known bug which is fixed after that. Since im using autosave 5-10-2 and the PVs are not very long, i gave up using autosave for this.
> Could you provide any details which might go into a ticket?
> Specific arguments used?  ideally a stack trace?  etc...
> https://github.com/epics-modules/autosave/issues
I haven't tried fdbrestore() previously, so I'm not certain about the
caput() errors.  It certainly didn't crash on me.
Did you do full cleanup and rebuild when switching between autosave versions?
(eg. "make distclean", or just deleting and re-downloading the source)
Linking in old object code files is great way to experience some bizarre crashes.
> epics> var save_restoreDebug 5
> epics> fdbrestore "ioc_settings.sav"
> save_restore:fdbrestore:entry
> save_restore:request_manual_restore: entry
> save_restore task: calling do_manual_restore('ioc_settings.sav')
> save_restore:do_manual_restore: entry for file 'ioc_settings.sav'
> epics> do_manual_restore:ca_put() to 'TST:Speed-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:DM-Sel.VAL'failed.
> do_manual_restore:ca_put() to 'TST:SampT-Sel.VAL'failed.
> do_manual_restore:ca_put() to 'TST:SampT:N-Sel.VAL'failed.
> do_manual_restore:ca_put() to 'TST:SampDet-Sel.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Plt-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Samp-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Plt:N-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Samp:N-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Gn:X-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Gn:Y-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Gn:Z-SP.VAL'failed.
> do_manual_restore:ca_put() to 'TST:Tl-Sel.VAL'failed.
> save_restore: manual restore status=1 (0==success)
How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Re: How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Prev: Re: Problem downloading from sequenzer repo Birke, Thomas via Tech-talk
Next: Re: Problem downloading from sequenzer repo Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Next: Re: How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
