1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: record with constant input link
From: Gerrit Kühn via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: Rolf Keitel via Tech-talk <[email protected]>
Date: Fri, 3 Nov 2023 17:49:24 +0100
Am Fri, 3 Nov 2023 16:36:31 +0000
schrieb "Johnson, Andrew N." <[email protected]>:
> > I see. But why is this written in the manual for stringin records
> > then?
> In recent EPICS 7 versions a stringin record can use a JSON "const"
> link<https://epics.anl.gov/base/R7-0/7-docs/links.html#Constant-Link-const>
> in its INP field to provide an initial constant string value, the older
> CONSTANT link type was limited to numeric values (see below). Even
> simpler though is just to set the VAL field in your .db file — this
> works fine as long as the INP field isn't also set.
Thanks to both of you for having the patience to explain this to me. Looks
like I somehow got lost in the documentation and stuck to the wrong lines.
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
Re: record with constant input link Johnson, Andrew N. via Tech-talk
Prev: Re: record with constant input link Johnson, Andrew N. via Tech-talk
Next: Re: Cannot do successful RS-232 communication with baud rates <2400 with VME and IP module Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: record with constant input link Gerrit Kühn via Tech-talk
