1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: record with constant input link
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 6 Nov 2023 09:32:26 +0100
On Mon, 6 Nov 2023 at 08:16, Gerrit Kühn via Tech-talk <[email protected]> wrote:
Is there a way to have selected records initialised before @init is being
run?
Well, in general: If you can't initialise records earlier, run @init later.
Can you set up your low level asyn drivers to connect to the device *after* iocInit has been run? Switching them to autoconnect at the end of the st.cmd?
Cheers,
~Ralph
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
Prev: Re: record with constant input link Ralph Lange via Tech-talk
Next: Re: record with constant input link Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
