1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: EPICS build problem
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Freddie Akeroyd - STFC UKRI <[email protected]>, 'Federico Galdenzi' <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 Apr 2025 11:38:09 +0000
If you can't build test.c then re-run the visual studio installer and check that the "desktop development with c++" component isn't missing items - it might be easier to try reinstall/repair it
Freddie
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Freddie
> Sent: 29 April 2025 11:49
> To: 'Federico Galdenzi' <[email protected]>; [email protected]
> Hi,
> Can you just try the following to check your compiler is working correctly
> From a new command window run       vcvarsall.bat  x64     which for me is
> running the command
>         "C:\Program Files\Microsoft Visual
> Studio\2022\Enterprise\VC\Auxiliary\Build\vcvarsall.bat" x64
> But your visual studio may be a different version or in a different location. It
> should reply with something like
>     ** Visual Studio 2022 Developer Command Prompt v17.11.5
>     ** Copyright (c) 2022 Microsoft Corporation
>     [vcvarsall.bat] Environment initialized for: 'x64'
> Now create a simple    test.c     file containing
> #include <stdio.h>
> int main(int argc, char* argv[])
>     printf("Test\n");
>     return 0;
> Now try and build this file with
>     cl test.c
> which should generate output to screen like
> C:\Users>  cl test.c
> Microsoft (R) C/C++ Optimizing Compiler Version 19.41.34123 for x64
> Copyright (C) Microsoft Corporation.  All rights reserved.
> test.c
> Microsoft (R) Incremental Linker Version 14.41.34123.0 Copyright (C)
> /out:test.exe
> test.obj
> if that works try running the executable
> C:\Users> test.exe
> Test
> Regards,
> Freddie
> > From: Federico Galdenzi <[email protected]>
> > Sent: 29 April 2025 10:05
> > To: [email protected]
> > Cc: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>;
> > Rivers <[email protected]>
> > Subject: Re: EPICS build problem
> > Dear Freddie and Mark, thanks again for your help. As you can see here
> > in the logs i still have the bug of not finding stdio.h and assert.h in my
> computer.
> > I know that this is basic but i cant' really find a solution.
> > Regards, Federico.
> > Il 2025-04-16 17:42 Freddie Akeroyd - STFC UKRI ha scritto:
> > > Hi,
> > > The windows.bat / win32.bat files just run vcvarsall.bat, set
> > > EPICS_HOST_ARCH and add perl to the PATH, so are just convenient
> > > shortcuts and not strictly necessary
> > > When vcvarsall.bat is run it needs an argument to tell it the build
> > > architecture, and this needs to match your intended EPICS_HOST_ARCH.
> > > So try
> > >     vcvarsall.bat x64
> > >     set EPICS_HOST_ARCH=windows-x64
> > > for a 64bit build. If you needed a 32bit built it would be:
> > >     vcvarsall.bat x86
> > >     set EPICS_HOST_ARCH=win32-x86
> > > Regards,
> > > Freddie
> > > Sent: 16 April 2025 14:18
> > > To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
> > > Cc: Rivers <[email protected]>; [email protected]
> > > Hi Freddie,
> > > I've followed this part of the tutorial:
> > > Download the distribution from e.g.
> > > https://urldefense.us/v3/__https://epics-
> controls.org/download/base/base-
> 7.0.4.1.tar.gz__;!!G_uCfscf7eWS!b1VOPd55aMpieZhLKuO5fB6xHdr4WQtS91
> bqVyiSoXDI-F_tOKheBmTAOnLr1yjNIzyHCSLQj88T6elXs4WxNO-
> mVLVqhKbCHqs$ .
> > > Unpack it into a work directory.
> > > Open a Windows command prompt and change into the directory you
> > > unpacked EPICS Base into.
> > > Note: The complete path of the current directory mustn’t contain any
> > > spaces or parentheses. If your working directory path does, you can
> > > do another cd into the same directory, replacing every path
> > > component containing spaces or parentheses with its Windows short
> > > path (that can be displayed with dir /x).
> > > Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for
> > > 64bit builds, win32-x86 for 32bit builds).
> > > Run the vcvarsall.bat script of your installation (the exact path
> > > depends on the type and language of installation) to set the
> > > environment for your build.
> > > Run make (or gmake if using the version from Strawberry Perl).
> > > When i cd to my folder, and typed "where cl" it doesnt' return
> > > anything not even after i ran the vcvarsall.bat. I didnt' ran the
> > > windows.bat because it wasn't written.
> > > Should i do it directly from the folder?
> > > Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
> > >> Hi,
> > >> In the startup directory of epics there are two bat files  "win32.bat"
> > >> and "windows.bat" - which did you use to setup the compiler path etc.
> > >>  win32.bat choses the compiler for 32bit builds and windows.bat for
> > >> 64bit builds. Your EPICS_HOST_ARCH environment variable is set for
> > >> a 64bit builds, but the error message suggests your build may be
> > >> using the 32bit compiler instead as the linker cannot target x64.
> > >> If you type
> > >>     where cl
> > >> do you see a path with x64 in it like
> Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.e
> > >> x
> > >> e
> > >> Or do you see x86 present instead?
> > >> Regards,
> > >> Freddie
> > >> Sent: 16 April 2025 08:15
> > >> To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>;
> > >> Cc: [email protected]
> > >> Thanks in advance for the help. I made the log for make and also i
> > >> can tell that i'm following by letter the tutorial that i've linked
> > >> to download and build epic base. I've installed perl and make manually.
> > >> Best regards.
> > >> Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
> > >>> Hi,
> > >>> We'll need to see a bit more of your build log to see exactly
> > >>> which libraries it is having a problem with, can you please post
> > >>> the whole build log by doing  something like
> > >>>     make clean uninstall
> > >>>     make > make.log 2>&1
> > >>> And posting make.log
> > >>> Thanks,
> > >>> Freddie
> > >>>> Federico Galdenzi via Tech-talk
> > >>>> Sent: 15 April 2025 12:36
> > >>>> Subject: EPICS build problem
> > >>>> Good morning all,
> > >>>> I have a problem for installing EPICS on my machine. I've
> > >>>> followed the instruction given in this site:
> > >>>> https://urldefense.us/v3/__https://docs.epics-
> > >>>> controls.org/en/latest/getting-started/installation-windows-
> plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
> > >>>> q5862JV6Ua7PGUqoY-
> > cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
> > >>>> but it seems that i'm missing something, because i get the "make"
> > >>>> fatal error
> > >>>> LNK1112: module machine type 'x86' conflicts with target machine
> > >>>> type 'x64'.
> > >>>> I'm kinda new to this world but i cant' manage to understand what
> > >>>> i'm doing wrong. It seems that i'm using 32 bit libraries on a 64
> > >>>> bit environment, but i'm using Visual Studio latests kit's for
> > >>>> developing in C++ in both 64 and
> > >>>> 32 bit.
> > >>>> What can i do?
EPICS build problem Federico Galdenzi via Tech-talk
RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Re: EPICS build problem Federico Galdenzi via Tech-talk
Prev: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Waveform to single ai (again) Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: EPICS build problem Federico Galdenzi via Tech-talk
