Can you just try the following to check your compiler is working correctly
From a new command window run vcvarsall.bat x64 which for me is running the command
"C:\Program Files\Microsoft Visual Studio\2022\Enterprise\VC\Auxiliary\Build\vcvarsall.bat" x64
But your visual studio may be a different version or in a different location. It should reply with something like
** Visual Studio 2022 Developer Command Prompt v17.11.5
** Copyright (c) 2022 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
Now create a simple test.c file containing
#include <stdio.h>
int main(int argc, char* argv[])
printf("Test\n");
return 0;
Now try and build this file with
cl test.c
which should generate output to screen like
C:\Users> cl test.c
Microsoft (R) C/C++ Optimizing Compiler Version 19.41.34123 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
test.c
Microsoft (R) Incremental Linker Version 14.41.34123.0
/out:test.exe
test.obj
if that works try running the executable
C:\Users> test.exe
Test
Freddie
> -----Original Message-----
> From: Federico Galdenzi <[email protected]>
> Sent: 29 April 2025 10:05
> To: [email protected]
> Cc: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Rivers
> <[email protected]>
> Subject: Re: EPICS build problem
> Dear Freddie and Mark, thanks again for your help. As you can see here in the
> logs i still have the bug of not finding stdio.h and assert.h in my computer.
> I know that this is basic but i cant' really find a solution.
> Regards, Federico.
> Il 2025-04-16 17:42 Freddie Akeroyd - STFC UKRI ha scritto:
> > Hi,
> > The windows.bat / win32.bat files just run vcvarsall.bat, set
> > EPICS_HOST_ARCH and add perl to the PATH, so are just convenient
> > shortcuts and not strictly necessary
> > When vcvarsall.bat is run it needs an argument to tell it the build
> > architecture, and this needs to match your intended EPICS_HOST_ARCH.
> > So try
> > vcvarsall.bat x64
> > set EPICS_HOST_ARCH=windows-x64
> > for a 64bit build. If you needed a 32bit built it would be:
> > vcvarsall.bat x86
> > set EPICS_HOST_ARCH=win32-x86
> > Regards,
> > Freddie
> > Sent: 16 April 2025 14:18
> > To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
> > Cc: Rivers <[email protected]>; [email protected]
> > Hi Freddie,
> > I've followed this part of the tutorial:
> > Download the distribution from e.g.
> > https://urldefense.us/v3/__https://epics-controls.org/download/base/base-7.0.4.1.tar.gz__;!!G_uCfscf7eWS!b1VOPd55aMpieZhLKuO5fB6xHdr4WQtS91bqVyiSoXDI-F_tOKheBmTAOnLr1yjNIzyHCSLQj88T6elXs4WxNO-mVLVqhKbCHqs$ .
> > Unpack it into a work directory.
> > Open a Windows command prompt and change into the directory you
> > unpacked EPICS Base into.
> > Note: The complete path of the current directory mustn’t contain any
> > spaces or parentheses. If your working directory path does, you can do
> > another cd into the same directory, replacing every path component
> > containing spaces or parentheses with its Windows short path (that can
> > be displayed with dir /x).
> > Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for 64bit
> > builds, win32-x86 for 32bit builds).
> > Run the vcvarsall.bat script of your installation (the exact path
> > depends on the type and language of installation) to set the
> > environment for your build.
> > Run make (or gmake if using the version from Strawberry Perl).
> > When i cd to my folder, and typed "where cl" it doesnt' return
> > anything not even after i ran the vcvarsall.bat. I didnt' ran the
> > windows.bat because it wasn't written.
> > Should i do it directly from the folder?
> > Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
> >> Hi,
> >> In the startup directory of epics there are two bat files "win32.bat"
> >> and "windows.bat" - which did you use to setup the compiler path etc.
> >> win32.bat choses the compiler for 32bit builds and windows.bat for
> >> 64bit builds. Your EPICS_HOST_ARCH environment variable is set for a
> >> 64bit builds, but the error message suggests your build may be using
> >> the 32bit compiler instead as the linker cannot target x64. If you
> >> type
> >> where cl
> >> do you see a path with x64 in it like
> Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.e
> >> x
> >> e
> >> Or do you see x86 present instead?
> >> Regards,
> >> Freddie
> >> Sent: 16 April 2025 08:15
> >> To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>;
> >> Cc: [email protected]
> >> Thanks in advance for the help. I made the log for make and also i
> >> can tell that i'm following by letter the tutorial that i've linked
> >> to download and build epic base. I've installed perl and make manually.
> >> Best regards.
> >> Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
> >>> Hi,
> >>> We'll need to see a bit more of your build log to see exactly which
> >>> libraries it is having a problem with, can you please post the whole
> >>> build log by doing something like
> >>> make clean uninstall
> >>> make > make.log 2>&1
> >>> And posting make.log
> >>> Thanks,
> >>> Freddie
> >>>> From: Tech-talk <[email protected]> On Behalf Of
> >>>> Federico Galdenzi via Tech-talk
> >>>> Sent: 15 April 2025 12:36
> >>>> Subject: EPICS build problem
> >>>> Good morning all,
> >>>> I have a problem for installing EPICS on my machine. I've followed
> >>>> the instruction given in this site:
> >>>> https://urldefense.us/v3/__https://docs.epics-
> >>>> controls.org/en/latest/getting-started/installation-windows-
> plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
> >>>> q5862JV6Ua7PGUqoY-
> cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
> >>>> but it seems that i'm missing something, because i get the "make"
> >>>> fatal error
> >>>> LNK1112: module machine type 'x86' conflicts with target machine
> >>>> type 'x64'.
> >>>> I'm kinda new to this world but i cant' manage to understand what
> >>>> i'm doing wrong. It seems that i'm using 32 bit libraries on a 64
> >>>> bit environment, but i'm using Visual Studio latests kit's for
> >>>> developing in C++ in both 64 and
> >>>> 32 bit.
> >>>> What can i do?
- RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: EPICS build problem Federico Galdenzi via Tech-talk
- EPICS build problem Federico Galdenzi via Tech-talk
RE: Compile StreamDevice with PCRE on windows Freddie Akeroyd - STFC UKRI via Tech-talk
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
<2025>
2026
<2025>
2026
