1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MAXnet Alarm State Under High Motor Command Load
From: "Peterson, Kevin M. via Tech-talk" <tech-talk at aps.anl.gov>
To: Jiajun Tian <jiajtian at uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 11 Feb 2026 22:04:39 +0000
If you uncomment the USR_CXXFLAGS line from omsAsynApp/srcMakfile:
https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fepics-motor*2FmotorOmsAsyn*2Fblob*2Fc0ae4c740d699e64f264ce6f53f23a492abf19fa*2FomsAsynApp*2Fsrc*2FMakefile*23L8&data=05*7C02*7Ctech-talk*40aps.anl.gov*7C7e3fe92b9b424215f20008de69b98d6c*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639064442806712722*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=IsSeeSktdQtqxbUAm78EBMPBRKKuaeeVMwjL6twDhJc*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!dHAFdnK_8UCdKq79G1haFr6fBekEzpWidjPb_DFqdwo4ay3zoLBMSFNLS5cE3c_-4xyP5YpScJ97LyAV-ZVAUZk$
and uncomment the motorOMSBASEdebug variable in omsAsynMAXnetSupport.dbd:
https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fepics-motor*2FmotorOmsAsyn*2Fblob*2Fc0ae4c740d699e64f264ce6f53f23a492abf19fa*2FomsAsynApp*2Fsrc*2FomsAsynMAXnetSupport.dbd*23L2&data=05*7C02*7Ctech-talk*40aps.anl.gov*7C7e3fe92b9b424215f20008de69b98d6c*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639064442806731460*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=8*2FNXRHoWvIBsMbSZGt4*2F7b2YGiRabV0Fymtm9Xn1kKc*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!dHAFdnK_8UCdKq79G1haFr6fBekEzpWidjPb_DFqdwo4ay3zoLBMSFNLS5cE3c_-4xyP5YpScJ97LyAVTJLwSnw$
and rebuild motorOmsAsyn and the IOC, you should then be able to set the variable on the IOC's shell:
var("motorOMSBASEdebug", 4)
which should result in a "setting Problem flag" message being printed.
Kevin
Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Prev: Re: eiger2 vacuum sequencing power status Maren Purves via Tech-talk
Next: Re: Support for piezo controller nanoFAKTUR EBD-060310 LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
