1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 2 MAXv problems
To: Eric Norum <[email protected]>, EPICS <[email protected]>
Date: Thu, 11 Mar 2010 12:57:12 -0500
Eric Norum wrote:
"Don't block" and "don't alloc/free" certainly are necessary conditions for a routine to be ISR safe. But as you indicate there are a lot more things to worry about as well. Given the range of architectures and compilers with which EPICS can be used I really think that it's best to stick to routines that are explicitly described as safe. This is especially true given that calling a non-safe routine is likely to result in a system that fails very occasionally in a manner that would be very hard to debug.
Could someone with a more up to date version of the vxWorks manual check and see if there have been additions to the "safe" list since the very old manual from which I quoted?
The "Routines Callable by ISRs" table from VxWorks 6.7 is pasted at the end of this message (sorry about the formatting). Not that different then the previous version you sent.
Looking at sprintf(), it can call malloc() internally which calls semTake() which is not ISR safe. (And it may also do other non-safe actions.)
Steven Hartman
[email protected] || 865-466-6473
Table 7-24 :Routines Callable by ISRs
Library
Routine
bLib
All routines
errnoLib
errnoGet( ), errnoSet( )
eventLib
eventSend( )
fppArchLib
fppSave( ), fppRestore( )
intLib
intContext( ), intCount( ), intVecSet( ), intVecGet( )
intArchLib
intLock( ), intUnlock( )
logLib
logMsg( )
lstLib
All routines except lstFree( )
mathALib
All routines, if fppSave( )/fppRestore( ) are used
msgQLib
msgQSend( )
rngLib
All routines except rngCreate( ) and rngDelete( )
pipeDrv
write( )
selectLib
selWakeup( ), selWakeupAll( )
semLib
semGive( ) except mutual-exclusion semaphores, semFlush( )
semPxLib
sem_post( )
sigLib
kill( )
taskLib
taskSuspend( ), taskResume( ), taskPrioritySet( ), taskPriorityGet( ), taskIdVerify( ), taskIdDefault( ), taskIsReady( ), taskIsSuspended( ), taskIsPended( ), taskIsDelayed( ), taskTcb( )
tickLib
tickAnnounce( ), tickSet( ), tickGet( )
tyLib
tyIRd( ), tyITx( )
vxLib
vxTas( ), vxMemProbe( )
wdLib
wdStart( ), wdCancel( )
2 MAXv problems Jens . Eden
Re: 2 MAXv problems Ron Sluiter
Re: 2 MAXv problems Jens . Eden
Re: 2 MAXv problems Dirk Zimoch
Re: 2 MAXv problems Eric Norum
Prev: Re: IP asyn timeout connection Dominique Touchard
Next: RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 2 MAXv problems Eric Norum
Next: Re: 2 MAXv problems Joachim Rahn
