Mark,
What thread synchronization is used between the two tasks that are seeing different data? The ARM memory model is stricter than the Intel one, so the code must release a mutex after writing to shared data, and take a mutex before reading from shared data. It is even possible that the epicsRingBuffer code doesn't properly follow the ARM rules, I would try running the relevant libCom tests to check that. I can't research anything more about it right now (I'm on vacation), but it's something you might want to double check.
- Andrew
Sent from my iPad
> On May 7, 2014, at 6:34 PM, "Mark Rivers" <[email protected]> wrote:
> I don't think this has anything to do with the problem we are seeing on the ARM5.
> The problem we are seeing does not have to do with passing the status bits to the motor record, it has to do with passing information in pasynUser->userData. This is an asyn issue, not a motor record issue.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of J. Lewis Muir
> Sent: Wednesday, May 07, 2014 11:29 AM
> To: [email protected]
> Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
>> On 5/7/14, 11:01 AM, Jens Eden wrote:
>> I don't know if this is the cause of the problem, but even on a
>> single architecture, you will need a correct entry in this switch in
>> motorApp/MotorSrc/motor.h
> Jens posted about this to the list in February:
> http://www.aps.anl.gov/epics/tech-talk/2014/msg00158.php
> From that thread, it sounds like the motor module needs some work to
> eliminate assumptions about, as Till Straumann wrote, "what storage unit
> the compiler uses, how adjacent bits are packed across a storage-unit
> boundary and in what order bits are allocated (LSB->MSB or MSB->LSB)."
> Lewis
- RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Jens Eden
Re: Future Roadmap of CSS Kasemir, Kay
<2014>
2025
2026
<2014>
2025
2026
