1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Killing caRepeater on Windows 10
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Mark Rivers via Tech-talk <[email protected]>
Date: Tue, 14 Jan 2020 17:52:15 +0000
> Only if I run the version of caget from this directory does it show up in the Task Manager.  If I run any other version it does not show up.
For what it's worth, on Linux the caRepeater process runs as a child process of for example camonitor.
Start first camonitor, and it starts a caRepeater.
End that camonitor via Ctrl-C, and the child caRepeater process also quits.
Is there a similar child/parent process hierarchy on windows?
Do those different cases that you see result in the same child process tree?
That might determine how/where/under which name the caRepeater shows up in task listings.
Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Prev: RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Next: Re: Killing caRepeater on Windows 10 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
