1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Killing caRepeater on Windows 10
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Tue, 14 Jan 2020 17:54:04 +0000
Hi Mark,
My guess is that the Windows Tools package was registering its caRepeater.exe with the system somehow in the MSI installer, and this causes it to appear in the Task Manager — we have lost the knowledge of exactly what it did since both Ken Evans and Janet retired. The installer sources should still exist somewhere though; if someone wants to try to understand and support them I can look for them.
Have you tried manually running the caRepeater to see if it then shows up in Task Manager? For me it does appear in the output of tasklist. It's just a regular program which the CA Client library attempts to spawn when it needs it, and when run in the foreground a Control-C will stop it again.
I'm in the process of trying to see if I can get it to be started automatically as a Windows Service by the Services app, which is probably the best way to do this. I am copying a static-built version to a different directory, so it won't then get in the way of rebuilding Base.
- Andrew
On 1/14/20 11:42 AM, Mark Rivers via Tech-talk wrote:
I repeated the previous experiment, but this time I first cd’d to the EPICS Windows Tools directory.  In that case “where caRepeater” shows this:
C:\Program Files\EPICS Windows Tools>where caRepeater.exe
C:\Program Files\EPICS Windows Tools\caRepeater.exe
H:\epics\base\bin\windows-x64-static\caRepeater.exe
C:\Program Files\caQTDM\bin\windows-x64\caRepeater.exe
So it should be launching the versio of caRepeater from 2014, from this directory.
The result was the same.  Only if I run the version of caget from this directory does it show up in the Task Manager.  If I run any other version it does not show up.  So I conclude it is the version of caget, and not caRepeater that matters?
Sent: Tuesday, January 14, 2020 11:32 AM
To: Matt Newville <[email protected]>
Cc: Engbretson, Mark S. <[email protected]>; [email protected]
Subject: RE: Killing caRepeater on Windows 10
I just did an experiment with 4 different versions of caget.  For each experiment I did the following:
-          Kill the existing caRepeater task
-          Run caget
-          See if caRepeater.exe showed up in Task Manager Details tab.
The versions of caget I tested were
7.0.3.1
3.15.5
3.14.12.6
The version that comes with the most recent EPICS Windows Tools, caRepeater.exe dated 7/8/2014.
Of these only the EPICS Windows Tools version produced a caRepeater.exe that appeared in the Windows 10 Task Manager.  All of the others started caRepeater, but it was not visible in Task Manger.
Another question might be what version of caRepeater is actually run.  I assume this is the first one found in the PATH.
J:\epics\devel\dxp>where carepeater
H:\epics\base\bin\windows-x64-static is a soft link to base-7.0.3.1, so that should be the version of caRepeater it is running.
Sent: Tuesday, January 14, 2020 10:16 AM
I do see caRepeater.exe appear in the Details tab of Task Manager on Windows 10 once a real CA connection is begun.
--Matt Newville
Complexity comes for free, Simplicity you have to work for.
Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Prev: Re: Killing caRepeater on Windows 10 Kasemir, Kay via Tech-talk
Next: Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Next: RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
