On Tue, Jan 14, 2020 at 11:52 AM Kasemir, Kay via Tech-talk < [email protected]> wrote:
> Only if I run the version of caget from this directory does it show up in the Task Manager. If I run any other version
it does not show up.
For what it's worth, on Linux the caRepeater process runs as a child process of for example camonitor.
Start first camonitor, and it starts a caRepeater.
End that camonitor via Ctrl-C, and the child caRepeater process also quits.
But that is not true for all CA processes. `caget XXX` will start caRepeater if it is not running, and caRepeater will not quit when caget exits normally. If the camonitor process is killed with `kill -9 PID`, the caReapeter it has launched will remain running.
Is there a similar child/parent process hierarchy on windows?
Do those different cases that you see result in the same child process tree?
That might determine how/where/under which name the caRepeater shows up in task listings.
--Matt Newville
- Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
- Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
- Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
- RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
- Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
- Re: Killing caRepeater on Windows 10 Kasemir, Kay via Tech-talk
Re: Killing caRepeater on Windows 10 Johnson, Andrew N. via Tech-talk
Re: [EXTERNAL] Re: CA_DISABLE_REPEATER Re: Killing caRepeater on Windows 10 Kasemir, Kay via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
