Subject: Re: XSPRESS3 hdf5 problems
From: John Dobbins via Tech-talk <[email protected]>
To: Matt Newville <[email protected]>
Date: Tue, 28 Jan 2020 19:04:42 +0000
OK. I modified iocxspress-4Channel for six channels. I'll try starting with iocGSECARS-4Channel.
John
Sent: Tuesday, January 28, 2020 1:59 PM
To: John Dobbins <[email protected]>
Cc: [email protected] <[email protected]>; Mark Rivers <[email protected]>
Hi John,
On Tue, Jan 28, 2020 at 12:24 PM John Dobbins <[email protected]> wrote:
First, thanks to Matt Newville and Mark Rivers for your help in getting my XSPRESS3 IOC running. (I'll post later it it actually fixes our original problem.)
I have two questions related to the IOC:
On IOC start-up I get 48 messages (6 channels x 8 SCAs) of this type:
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA1:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA2:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA3:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
I don't see those messages, but they look familiar: This seems like it might be related to changes that were made for TimeSeries around AD3.5 or AD3.6.
I'm using the "iocGSECARS-4Channel" boot directory, which needs the more recent versions of AD.  It may be that the other iocBoot directories are still using TimeSeries syntax that are based on AD2 (I think it might be "up to AD3.5"), which are subtly different than for AD 3.6 and higher.   Does that seem it might be the culprit?  If so, we should update all the iocBoot directories to be consistent with the latest version of AD3.
Plus this message:
2020/01/28 12:57:33.650 asynNDArrayDriver:readNDAttributesFile: unknown attribute type = INT for attribute CHAN1DTCFLAGS
Oh, yes I do see that. The XSP3.xml NDAttributesFile has
    <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="INT"/>
which should probably be
    <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="PARAM"/>
We should fix that in master.
--Matt Newville
XSPRESS3 hdf5 problems John Dobbins via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Prev: Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Next: Job Openings at ORNL for the STS Project Steven M. Hartman via Tech-talk
Next: CAEN SY127 via RS232 Jan Glorius via Tech-talk
