1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PV Access
From: "Kivel Niko \(PSI\) via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Thu, 26 Mar 2020 19:05:35 +0000
Hi Andrew
Thank you very much for the detailed answer.
To me the bottom line is: "so calc links aren’t terribly useful at the moment"
Unfortunately, I'm not in the position to contribute in any capacity to the implementation of the features laid out in the course of this conversation. But, I'd love to have the features described in the wiki 😊
Thanks again, and sorry to you Rolf for highjacking your thread.
best
Niko
Paul Scherrer Institute
Dr. Niko Kivel
Forschungsstrasse 111
WBGB/017
5232 Villigen PSI
Switzerland
phone: +41 56 310 2226
email: [email protected]
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Sent: Thursday, March 26, 2020 19:39
To: EPICS tech-talk
Okay, I need to apologize for using non-existent but potential link types in my examples when developing my proposals and documentation, they appear to have caused a fair bit of confusion – my intention was to show what could be possible in the future. Hopefully this rather long email will clarify the current state rather than confuse interested readers, in it I’m trying to answer all the points and questions raised up-thread.
As a few people have pointed out, there are no “ca” or “db” link types available in current releases; anywhere you see those in documentation or on Wiki pages was just meant as potential examples, to show what might be possible. Actually the current API doesn’t let us create a “db” JSON link type yet because of the requirement for those links to join the two records involved into the same lock-set. There will be a Channel Access (“ca”) link type at some point, but it isn’t available yet (Michael started developing one but it has issues with locking when talking to local CA channels, so I suspect a different approach may be needed).
The JSON link types that are available in your installation of EPICS Base from the core database module are documented in the file html/links.html that is installed during the build, or from the appropriate online version of that. This file doesn’t document the “pva” link type though, which comes from the separate pva2pva module and is documented as part of QSRV. Note that your IOC does need to be built with the qsrv.dbd file to be able to use “pva” links.
As to Ben’s questions about what a record name is allowed to contain, this was one of my concerns when adding JSON links, and after consulting the core developers and asking other community members at the SNS collaboration meeting, the IOC’s link field parser had to become stricter to be able to support them.
It has never been the intention that record names may contain any unreserved character. Since Base-3.13.0 the Application Developers Guide has (in an admittedly slightly obscure location) documented which characters are supposed to be allowed in a record name. However because the IOC code didn't actually enforce any limitations when loading records, sites have been using characters in record names that go against what the documentation says for a long time. I have tried to avoid breaking those cases, but I can’t 100% guarantee that we won’t change things further in the future.
In the last published version of the Application Developers Guide (for Base-3.16.2) section 6.4.11.2 says:
record_name
The record name. This must be composed out of only the following characters:
a-z A-Z 0-9 _ - + : [ ] < > ;
NOTE: If macro substitutions are used the name must be quoted.
Note that the presence of quote characters and the $ sign make {db:"${SYS}:constFloatPi"} an invalid record name, and an EPICS 7 IOC will now print a warning message if it sees a space, single- or double-quote character, period or dollar sign in a record name (see dbRecordHead() in dbLexRoutines.c).
When the IOC parses a link field value (dbParseLink() in dbStaticLib.c) it first strips any leading and trailing spaces, then if the string starts with ‘{‘ and ends with ‘}’ it is taken to be a JSON link address. The main user of brace characters in PV names that I could find at the time was NSLS-2, and their record names never match that pattern, so this rule doesn’t impact them. Similarly if the string starts with ‘[‘, ends with ‘]’ and contains at least one comma or double-quote character between those brackets, it is now a constant array. Only names that don’t match these and the older name tests can be parsed as record names in a DB or CA link.
When parsing a JSON link string the dbLoadRecords() code only looks at the syntax of the JSON, so it’s possible to load a .db file that refers to a link tag such as “db” that doesn’t exist (or that hasn’t been registered with the IOC yet). Later on the iocInit() process will parse that link properly and won’t be able to find the requested link tag, so it will flag an error at that point.
The example _expression_ in the calc link documentation shows the use of a “db” link tag that doesn’t actually exist or work today, so calc links aren’t terribly useful at the moment since you can’t use the old-style DB/CA/CONST links in the “args” tag, only JSON link types (Ralph’s assumption that the calc link type was doing something special to support DB-links was unfortunately wrong, the documentation for the calc::args tag that Ben pointed to is correct so hopefully it doesn’t need any more clarification). I will change the example shown in the documentation to use a “pva”  link instead.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
PV Access Rolf Keitel via Tech-talk
Re: PV Access Johnson, Andrew N. via Tech-talk
Re: PV Access Kivel Niko (PSI) via Tech-talk
Re: PV Access Ralph Lange via Tech-talk
Re: PV Access Ben Franksen via Tech-talk
Prev: Re: PV Access Johnson, Andrew N. via Tech-talk
Next: Re: PV Access Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
