Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 18:59:38 +0000
On Jun 18, 2020, at 10:58 AM, Ralph Lange via Tech-talk <[email protected]> wrote:
And, honestly: Connecting to a live IOC to be able to see the log of a previous run... I would call that a risk, not a feature.
When it’s 3am and you’re diagnosing a problem on an IOC, you’re already connected to its console and you want to see whether the previous boot gave a similar warning message, it’s a lot easier to page up than it is to connect to some other system (which you probably don’t use very often) just to view the logfile.
We don’t currently keep a permanent record of the console output from our IOCs but that is also on my list to implement for the APS Upgrade. I haven’t decided yet whether to do the logging using procServ or screen. I also want to provide the same interface to all our IOC consoles, both soft IOCs run under procServ and those that screen connects to via ssh to their terminal server. If I use screen to do the logging then the same logging solution works for both kinds of IOC; if I use procServ I still have to work out how to log the ssh-connected IOCs.
It’s a risk, but screen has been an essential part of our systems since we started using soft IOCs without our hitting that issue to my knowledge. I don’t have an alternative solution, I assume tmux might behave the same?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: Re: EPICS R3.15.8 and asubRecord issue. Johnson, Andrew N. via Tech-talk
Next: RE: RE: No PV record found when build ASYN application on Windows Freddie Akeroyd - UKRI STFC via Tech-talk
Prev: Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Next: Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
