Subject: Re: How to run IOC in docker containers properly
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 14:24:29 -0500
On 06/18, Johnson, Andrew N. via Tech-talk wrote:
> It’s a risk, but screen has been an essential part of our systems since we started using soft IOCs without our hitting that issue to my knowledge. I don’t have an alternative solution, I assume tmux might behave the same?
If you're asking whether tmux can log, the answer is yes, using the
pipe-pane command.  With that command, you can pipe the output of a tmux
pane to a shell command which can arrange for the output to be saved to
a file.  The shell command could be as simple as "cat >> ~/foo.log" or
more complex like running a logging program such as s6-log [1] that can
safely log to a file and handle file rotation.
Lewis
[1]: https://www.skarnet.org/software/s6/s6-log.html
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
Next: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
