1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 19:40:02 +0000
Hi Lewis,
On Jun 18, 2020, at 2:24 PM, J. Lewis Muir <[email protected]> wrote:
On 06/18, Johnson, Andrew N. via Tech-talk wrote:
It’s a risk, but screen has been an essential part of our systems since we started using soft IOCs without our hitting that issue to my knowledge. I don’t have an alternative solution, I assume tmux might behave the same?
If you're asking whether tmux can log, the answer is yes, using the
pipe-pane command.
No, I’m asking what tmux does if you run an IOC in it that generates messages occasionally, then use the ability to look back in its scroll-back buffer and leave your window scrolled to the very beginning of the buffer for a long time after the buffer has reached its size limit. Does it eventually freeze the IOC by imposing flow-control on the stdout/stderr stream from the IOC?
That was the problem that GNU Screen apparently has which triggered the writing of procServ.
Eric, you would probably never leave a Screen session in that state yourself, but please give it a go if you have time...
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly Jeong Han Lee via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Next: new version for CA Lab (EPICS <-> LabVIEW interface) 1.7.0.1 Carsten Winkler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: How to run IOC in docker containers properly Jeong Han Lee via Tech-talk
