Subject: Re: How to run IOC in docker containers properly
From: Jeong Han Lee via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 13:21:56 -0700
Now, I am confused about all discussions, do we discuss "logging" or
do we discuss "interactive shell"?
Or Does anyone would like to achieve both goals without any limitations?
Han
On Thu, Jun 18, 2020 at 12:40 PM Johnson, Andrew N. via Tech-talk
<[email protected]> wrote:
> Hi Lewis,
> On Jun 18, 2020, at 2:24 PM, J. Lewis Muir <[email protected]> wrote:
> On 06/18, Johnson, Andrew N. via Tech-talk wrote:
> It’s a risk, but screen has been an essential part of our systems since we started using soft IOCs without our hitting that issue to my knowledge. I don’t have an alternative solution, I assume tmux might behave the same?
> If you're asking whether tmux can log, the answer is yes, using the
> pipe-pane command.
> No, I’m asking what tmux does if you run an IOC in it that generates messages occasionally, then use the ability to look back in its scroll-back buffer and leave your window scrolled to the very beginning of the buffer for a long time after the buffer has reached its size limit. Does it eventually freeze the IOC by imposing flow-control on the stdout/stderr stream from the IOC?
> That was the problem that GNU Screen apparently has which triggered the writing of procServ.
> Eric, you would probably never leave a Screen session in that state yourself, but please give it a go if you have time...
> - Andrew
> Complexity comes for free, simplicity you have to work for.
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: new version for CA Lab (EPICS <-> LabVIEW interface) 1.7.0.1 Carsten Winkler via Tech-talk
Next: Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
Prev: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
