Subject: Re: running gateway on mac
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 2 Sep 2020 08:48:27 +0200
On Tue, 1 Sep 2020 at 19:35, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
To be honest, I have to reread this https://epics.anl.gov/base/R3-14/12-docs/CAref.html
Configuring a CA Server every time I set up a gateway.
Minor comment:
As you can see from the URL, these documents are versioned. Please always use the version that matches your version of Base.
The CA Reference Manual is part of the EPICS Base repository, so the applicable version is also prepared as part of the Base build/install for off-line use.
Cheers,
~Ralph
AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
running gateway on mac Vivian O'Dell via Tech-talk
Re: running gateway on mac Smith, Martin via Tech-talk
Re: running gateway on mac Vivian O'Dell via Tech-talk
Re: running gateway on mac Pierrick M Hanlet via Tech-talk
Prev: Re: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does not recover communication Jeong Han Lee via Tech-talk
Next: Re: Case insensitive macros in streamDevice protocol file O'Hea, James (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: running gateway on mac Pierrick M Hanlet via Tech-talk
Next: Case insensitive macros in streamDevice protocol file O'Hea, James (DLSLtd, RAL, LSCI) via Tech-talk
