Subject: AW: combining long strings
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Lang, Keenan C." <[email protected]>, "Johnson, Andrew N." <[email protected]>
Date: Thu, 11 Feb 2021 17:10:52 +0000
Hello Keenan,
>Is the error every time you attempt to set a value or does it just pop up at IOC start?
It is on IOC start. When I change the string values in the mbbo-records, nothing happens. No new error messages appear, the luascript record stays the same. I cant even trigger it in the console:
epics> dbtr Topo:FilePath
record active
From “dbpr Topo:FilePath 10” I see, that
TIME: <undefined>
NSTA: LINK
ERR: 1: attempt to concatenate a nil value (global 'AA')
Basically the same status like I posted on Wed, 3 Feb 2021 14:05:49 +0000.
Von: Lang, Keenan C. <[email protected]>
Gesendet: Donnerstag, 4. Februar 2021 21:26
An: Sintschuk, Michael <[email protected]>; Johnson, Andrew N. <[email protected]>
Cc: [email protected]
Betreff: Re: combining long strings
Michael,
It looks like having multiple CP links can process the record while at least one of the links isn't fully connected. Since the link isn't connected, the field for that value reports a nil value which causes the error when it attempts to concatenate. I need to look into the behavior and coding of the calc-style records and see how they behave and what I'm doing wrong, but once all the CP links are connected, the record does correctly grab the string value rather than the index value. If that weren't the case you wouldn't be getting an error, you'd just be getting a string with a number in the middle instead of the text you wanted.
Keenan
Sent: Thursday, February 4, 2021 4:14 AM
To: Lang, Keenan C. <[email protected]>; Johnson, Andrew N. <[email protected]>
Cc: [email protected] <[email protected]>
Hello Andrew, Keenan,
I pulled now the recent luascript-master and rebuild the module/IOC. Now I get the following error:
Calling return table.pack(string.byte(AA..CC, 1, -1)) resulted in error: 1: attempt to concatenate a nil value (global 'AA')
I think, it tries to concatenate the index-value of the mbbo-record and not the string-value. If I write my template like this:
record(luascript,"$(exp):FilePath") {
  field(INAA,"$(exp):PathMenu.ZRST CP")
  field(INCC,"$(exp):SampleMenu.ZRST CP")
  field(CODE,"return table.pack(string.byte(AA..CC, 1, -1))")
  field(OUT,"$(cam):$(format)1:FilePath PP")}
It concatenates and puts the string correctly, without errors. But this way I always look at the same string…
Gesendet: Donnerstag, 4. Februar 2021 01:31
An: Johnson, Andrew N. <[email protected]>
Cc: Sintschuk, Michael <[email protected]>; [email protected]
Andrew,
I wasn't before, but I have now changed the errLog function to also write out using errlogPrintf.
Keenan
Sent: Wednesday, February 3, 2021 12:33 PM
[email protected]>
[email protected]>; [email protected] <[email protected]>
Subject: Re: combining long strings
Hi Keenan,
On Feb 3, 2021, at 12:05 PM, Lang, Keenan C. <[email protected]> wrote:
The ERR field has an error in it, so the record did try to process, it just never successfully completed. I haven't seen that error before, but it appears that it points to some sort of issue with invalid memory access during the code execution. I'm trying to track down what went wrong.
Thanks for correcting me, I didn’t notice that PACT was still 1.
Does it also log lua errors using errlogPrintf() or an equivalent? I would want the IOC's error log to have a record of this kind of problem, and to not have to monitor the ERR fields of all the lua records.
- Andrew
Sent: Wednesday, February 3, 2021 12:01 PM
To: Sintschuk, Michael <
[email protected]>
Cc: Lang, Keenan C. <
Hi Michael,
On Feb 3, 2021, at 8:05 AM, Sintschuk, Michael via Tech-talk <[email protected]> wrote:
I like the luascript script solution. But unfortunately it won’t work for me. The record is always in SEVR: invalid mode and there is no input to the AA, BB … fields:
PINI: NO            PJ: 0               PJJ: 0x88d770       PPN: (nil)
PPNR: (nil)         PREC: 0             PRIO: LOW           PROC: 0
PSVL:               PUTF: 0             PVAL: 0             RDES: 0x80c5f0
RELO: Every New File                    RPRO: 0             RPVT: 0x88d570
RSET: 0x7f8e4c1d9e40                    SCAN: Passive       SDIS:CONSTANT
SEVR: INVALID       SPVT: (nil)         STAT: UDF           STATE: 0x88d7a8
SVAL:               SYNC: Sync          TIME: <undefined>   TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 1              UDFS: INVALID
VAL: 0              WAIT: NoWait
epics>
Did I missed something with the record settings?
Your record doesn’t appear to have been processed at all yet (STAT is UDF, UDF is 1 and TIME is <undefined>). Does processing it change the result? You can have that happen automatically when the IOC boots by setting PINI to YES, or manually with this iocsh command:
dbpf Topo:FilePath.PROC 1
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: combining long strings Johnson, Andrew N. via Tech-talk
combining long strings Sintschuk, Michael via Tech-talk
Re: combining long strings Lang, Keenan C. via Tech-talk
AW: combining long strings Sintschuk, Michael via Tech-talk
Prev: Phoebus development Vishnu Patel via Tech-talk
Next: Re: combining long strings Johnson, Andrew N. via Tech-talk
Prev: Re: combining long strings Lang, Keenan C. via Tech-talk
