So I just hardcoded in addr/bcast to see if the rest of the script would function correctly and now it gets down to the iptables command that sets up the rules. But when I check sudo iptables -L -v -n I am not seeing it added for some
reason.
jetson@ubuntu:/etc/network/if-up.d$ sudo ifup ens33
Internet Systems Consortium DHCP Client 4.3.5
Copyright 2004-2016 Internet Systems Consortium.
All rights reserved.
For info, please visit
https://www.isc.org/software/dhcp/
Listening on LPF/ens33/00:0c:29:c6:6f:a0
Sending on LPF/ens33/00:0c:29:c6:6f:a0
Sending on Socket/fallback
DHCPDISCOVER on ens33 to 255.255.255.255 port 67 interval 3 (xid=0xe228736a)
DHCPREQUEST of 192.168.252.132 on ens33 to 255.255.255.255 port 67 (xid=0x6a7328e2)
DHCPOFFER of 192.168.252.132 from 192.168.252.254
DHCPACK of 192.168.252.132 from 192.168.252.254
cmp: EOF on /tmp/tmp.nKI1m7I1fj which is empty
/sbin/dhclient-script: 8: /etc/dhcp/dhclient-exit-hooks.d/chrony: /usr/lib/chrony/chrony-helper: not found
bound to 192.168.252.132 -- renewal in 889 seconds.
+ PORT=5064
+ [ dhcp != none ]
+ [ ens33 != lo ]
+ ip addr show ens33
+ line=2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff
inet 192.168.252.132/24 brd 192.168.252.255 scope global ens33
valid_lft forever preferred_lft forever
inet6 fe80::20c:29ff:fec6:6fa0/64 scope link tentative
+ addr=192.168.252.132
+ bcast=192.168.252.255
+ [ -z 192.168.252.132 -o -z 192.168.252.255 ]
+ [ start = start ]
+ iptables -t nat -A PREROUTING -d 192.168.252.132 -p udp --dport 5064 -j DNAT --to-destination 192.168.252.255
+ exit 0
jetson@ubuntu:/etc/network/if-up.d$ sudo iptables -L -v -n
Chain INPUT (policy ACCEPT 381K packets, 587M bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
0 0 DOCKER-USER all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 DOCKER-ISOLATION-STAGE-1 all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- * docker0 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 DOCKER all -- * docker0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- docker0 docker0 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 192K packets, 17M bytes)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
0 0 DOCKER-ISOLATION-STAGE-2 all -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
0 0 DROP all -- * docker0 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-USER (1 references)
Thanks Heinz,
I seem to be still getting the return error from Ralph’s script even with the changes below that you mentioned. I did have to add the closing quotations on the last grep commands for addr/bcast, I was getting unterminated string error.
line=`ip addr show $IFACE`
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
[ -z "$addr" -o -z "$bcast" ] && return 1
@Ralph
Here is what the script is going through, seems like the grep is still failing
jetson@ubuntu:/etc/network/if-up.d$ sudo sh -x ioc.sh
+ PORT=5064
+ [ != none ]s
+ [ != lo ]
+ ip addr show
+ line=1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:6a:5e:1a:03 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
+ echo 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128
scope host valid_lft forever preferred_lft forever 2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff inet 192.168.252.132/24 brd 192.168.252.255 scope global
ens33 valid_lft forever preferred_lft forever inet6 fe80::20c:29ff:fec6:6fa0/64 scope link valid_lft forever preferred_lft forever 3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default link/ether 02:42:6a:5e:1a:03
brd ff:ff:ff:ff:ff:ff inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0 valid_lft forever preferred_lft forever
+ grep -Po inet\s+[^\s]+\s+
+ grep -Po \d+.*’
+ addr=
+ grep -Po \d+.*’
+ grep -Po brd\s+[^\s]+\s+
+ bcast=
+ [ -z -o -z ]
+ return 1
[email protected] On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, March 19, 2021 9:35 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Multiple IOCs on one host Issue
The right expressions might be these ones:
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’`
Do these work with older systems - where the other expressions worked?
